Adding Album to playlist
Postby c0utta » Fri Jul 22, 2016 5:58 pm
I can easily add a complete album to a synced playlist, but I had expected that all songs on that album would also be synced at the next interval.
Am I missing something?
c0utta
Re: Adding Album to playlist
Postby daneren2005 » Fri Jul 22, 2016 7:41 pm
Do all the songs on the album show up in the Playlist? They will only be synced if they are part of the playlist.
Postby c0utta » Mon Jul 25, 2016 1:35 pm
No, within the playlist I see a "stub" with a graphic of the album art, but none of the tracks have synced.
https://www.dropbox.com/s/ye7vozyjz97u60e/Screenshot_20160725-225942.png?dl=0
https://www.dropbox.com/s/idwouvtnu0d6wpo/Screenshot_20160725-230141.png?dl=0
c0utta
Postby daneren2005 » Mon Jul 25, 2016 10:30 pm
The first image is of the artist and the second is of the album. Neither are the playlist. Can you take a screenshot of the playlist?
Postby c0utta » Mon Jul 25, 2016 11:42 pm
No, the first screenshot is definitely the playlist (which is called "c0utta" FYI)
c0utta
Postby daneren2005 » Mon Jul 25, 2016 11:47 pm
There is no such thing as an album in a playlist...
Postby daneren2005 » Mon Jul 25, 2016 11:48 pm
You aren't using a stock Subsonic server are you?
Postby c0utta » Tue Jul 26, 2016 12:29 am
Yes, there is! Navigate to albums for an artist within the library. Long press and album, and the option to "Add To Playlist" becomes available.
https://www.dropbox.com/s/g6v10ffvn3q2e56/Screenshot_20160726-095558.png?dl=0
Stock standard Subsonic
Version 5.2.1 (build 4428) – March 4, 2015
c0utta
Postby daneren2005 » Tue Jul 26, 2016 12:42 am
That is a bug. You shouldn't be able to add an album to a playlist because that doesn't really make sense. I am surprised the API even allowed that as it is designed for entries not folders. I will fix that being an option in the next release.
Postby c0utta » Tue Jul 26, 2016 1:09 am
I thought it was a bug since it didn't sync, but thanks for confirming.
I'll add the tracks individually in the future.
c0utta
Return to DSub for Android
