Error username may not be null no library data
Postby betchman » Thu Aug 11, 2016 11:13 pm
I am having trouble getting dsub to work properly. I have entered in my server connection, and I have tested the connection. The connection test works fine. I can also open the web app through the link in the server setup. But when I try to access my library, I see that it says no data. If I navigate home, and try to open anything, I get an error that reads, " Username may not be null." Any help would be appreciated.
betchman
Re: Error username may not be null no library data
Postby daneren2005 » Fri Aug 12, 2016 1:06 am
It sounds like something got messed up in the install. Could you try wiping DSub's data cache?
Postby betchman » Fri Aug 12, 2016 1:27 pm
Thanks for the reply! I tried uninstalling the program, and then rebooting my phone. Next when I setup the program, I did not delete the demo server, I added my server. It worked perfectly this time.
I am amazed at how well this app works now.
betchman
Return to DSub for Android
