Battery drain with Android 7
Postby plastikman » Sat Nov 12, 2016 8:31 pm
Has anyone else experienced high battery drain with Android 7 on the n6?
If I listen to dsub (locally cached music) the battery drains hard core. I have listened to about 2 hours of music, phone has been on for 5 hours, battery is at 50%.
Here are some screenshots
https://imgur.com/a/N2YKN
It seems that dsub keep the CPU awake not allowing the phone to go into low power mode. With Android 6 this was never an issue.
I have wiped my phone, clean Installed the OS. I have ran with sock kernels and with Franco kernel. The issue seems to be related to dsub and Android 7. The abysmal battery life makes me want to downgrade.
Here are the logs I just created.
Android SDK: 24
Device Model: Nexus 6
Device Name: motorola shamu
ROM: NBD90Z
Logs: https://pastebin.com/z6TLFRMT
Build Number: 192
plastikman
Re: Battery drain with Android 7
Postby daneren2005 » Tue Nov 15, 2016 6:16 pm
Yes a few others have reported it as well. I am trying to narrow down why it is happening to some but not others: https://github.com/daneren2005/Subsonic/issues/751
Postby plastikman » Wed Nov 16, 2016 12:52 am
Thanks. I have subbed to the github thread and installed the package that was listed.
I will keep the thread on github updated.
plastikman
Return to DSub for Android
