Sync ALL songs?
Sync ALL songs?
Postby TheScoop » Thu Aug 03, 2017 8:01 am
So I bought a 200GB microSD card and now I can easily fit my entire collection on my phone.
Is there any way I can just go and sync my entire collection, over wifi?
This will decrease my mobile data consumption tremendously. Then, from there, I'll just have DSub sync new/updated content.
TheScoop
Re: Sync ALL songs?
Postby TheScoop » Thu Aug 03, 2017 8:09 am
I am able to slowly achieve this to some extent by shuffling a playlist at 100 songs a time on wifi, but its a slow process and obviously has diminishing returns. Do I need to copy the folders manually somehow? And what if I have "Browse by Tags" option enabled on my server? Thanks
TheScoop
Re: Sync ALL songs?
Postby Tak-MK » Thu Aug 03, 2017 8:14 am
I suppose copying the music on the sd? I never tried that.
Tak-MK
Re: Sync ALL songs?
Postby flvinny521 » Mon Nov 13, 2017 6:45 pm
Are you still working on this? Any updates? I am having some trouble.
My idea was to create a playlist on the server that contains all tracks, and then in DSub, I select the playlist, and from the menu, choose permanent cache. Even on a brand new Pixel 2 XL, the download pauses sometimes. I have to exit DSub, launch the app again, and then choose the permanent cache option again. It will begin where it left off.
I then put DSub into offline mode and can browse the available playlists and library entries that have been cached. However, my issue is that if I attempt to play tracks via a playlist, the music plays fine. However, if I try to browse the library, the app returns a list of all the artists, but no tracks are found. I am not sure why this is the case, and it appears DSub is dead, so making a bug report on github seems like a waste.
Edit: Copying the music onto the device or SD card has not worked well for me.
flvinny521
Return to DSub for Android
