Set DSub as default music player
Postby bluebir11 » Fri Dec 11, 2020 5:09 pm
Hi, I want to set DSub as the default music player on Android, but it doesn't show up in the list (system settings -> Apps -> default apps -> music app).
The use case is to start DSub automatically when I press the play button on a headset / car. When Google play music used to be my default it started ok, after I disabled it nothing happens when I press the play button, unless I manually start DSub first.
Can you add this? Thanks for all the recent updates they are really awesome!
bluebir11
Return to DSub for Android
