Release Notifications for UltraSonic
Discussion for the UltraSonic App for Android
Postby archrival » Sun Apr 28, 2013 7:20 am
Information about each release will be posted in this thread.
archrival
UltraSonic 1.1.0.6
Postby archrival » Sun Apr 28, 2013 7:22 am
Minor release: 1.1.0.6
This release fixes a bug in the "Select Folders" selection on the Artists screen.
archrival
UltraSonic 1.1.0.7
Postby archrival » Sun Apr 28, 2013 10:07 pm
Minor release: 1.1.0.7
Fixed a bug with Bluetooth notification
Updated French translation
Updated Hungarian translation
archrival
UltraSonic 1.1.0.8
Postby archrival » Sun Apr 28, 2013 10:08 pm
Minor release: 1.1.0.8
Fixed a bug with starring of albums
Removed song context menu
Added Play Next button
archrival
Re: Release Notifications for UltraSonic
Postby archrival » Sun May 05, 2013 2:10 am
Minor release: 1.1.0.10
Looks like I missed version 1.1.0.9, oh well.
Settings and About now part of the Menu
Settings and About now themed
About screen overhaul
Jukebox volume control now at 5% intervals
Jukebox volume control now themed
Tweaked widget
Play Now context menus available for Artists and Albums
Changed icon on pinned songs to a pin icon from a floppy icon
archrival
Postby archrival » Sun May 05, 2013 2:12 am
Semi-major release: 1.1.0.11
If it isn't apparent by now, I'm a big fan of release early and release often. I want to focus on one big feature at a time for a release, so just because some features haven't been worked on yet, that doesn't mean they aren't in the TODO list.
With that being said, here's the release notes for 1.1.0.11.
Added support for up to 10 servers
Added ability to add/remove servers, can have anywhere from 0 to 10 server entries
Added ability to enable/disable servers
Removed the word UltraSonic from the app icon
archrival
Postby archrival » Sun May 05, 2013 5:50 am
Minor release: 1.1.0.15
Fixed certain scenarios when removing servers
Genre list workaround for Madsonic beta
Other minor code bugfixes
This release contains improvements ported from DSub (https://github.com/daneren2005/Subsonic)
Many thanks to the developers!
Enhanced playlists
Offline playlists
Offline searching
Improved audio playback responsiveness
Improved UI responsiveness
Added gapless playback
Equalizer stability tweaks
Skip ahead on long press of previous/next (length is configurable in settings)
archrival
UltraSonic 1.1.0.17
Postby archrival » Sat May 18, 2013 11:25 am
Minor release: 1.1.0.17
Added support for ID3 tag methods (enable Browse Using ID3 Tags in settings). This enables methods for accessing the media collection organized according to ID3 tags, rather than file structure. Madsonic may have issues with this option, so be prepared. I will be reporting a bug with the handling of ID3 tags soon.
Really fixed Play Next
archrival
UltraSonic 1.1.0.18
Postby archrival » Mon May 20, 2013 6:53 am
Minor release: 1.1.0.18
Added expanded notification for Jelly Bean devices
Third time is a charm for the Play Next fix, I hope
This release focuses mainly on memory issues and latency issues within the application, hopefully it feels snappier.
archrival
UltraSonic 1.1.0.19
Postby archrival » Fri May 24, 2013 8:24 am
Minor release: 1.1.0.19
Added Chat Support, this has a corresponding refresh interval which is configurable in Settings. Regardless of the interval, it should not refresh if the Chat screen is not open. If there is enough interest I may expand on the chat feature.
Fixed some minor bugs.
archrival
UltraSonic 1.1.0.20
Postby archrival » Wed May 29, 2013 8:25 am
Added 4x2, 4x3 and 4x4 widgets. These may be 3x2, 3x3 and 3x3 on some devices. I'm probably not done with these, but this is a start.
Moved track title above artist
Added playlist current track / total tracks to Now Playing screen
Added total playlist time to Now Playing screen
Enabled fast scroll on all ListViews
Added unpin to most context menus
Scroll playlist to current track on track change
Added setting for Directory Cache Time
Added download option
archrival
UltraSonic 1.1.0.22
Postby archrival » Wed May 29, 2013 8:26 am
Added Bookmark support (single press to add/update the bookmark, long press to delete it). Playback of the bookmark can only occur in the bookmark screen for the time being. Let me know of any improvements you would like to see. I also added an option to delete the bookmark upon completion of the playback of the track, it is disabled by default.
Added Jukebox by default server option, this will set the jukebox to on when selecting the server
Added option to clear playlist on completion of playlist playback
Added option to sort by disc and track. If your tags are inconsistent, I wouldn't recommend this option if you are satisfied with the default sort order provided by the server.
Moved Playlist Toggle, Star, Remove All and Save Playlist to a new row of buttons for quicker access. Not sure I like it, but I'm also not sure how I can add any more to the playlist/playback screen. It is starting to feel a little cluttered.
Moved download status text to ActionBar subtitle
Added opaque background for visualizer
archrival
UltraSonic 1.1.0.23
Postby archrival » Sat Jun 01, 2013 5:16 am
Ported MX Player video playback from official Subsonic app
Bluetooth tweaks
Other minor bugfixes
archrival
UltraSonic 1.2.0.1
Postby archrival » Tue Jun 04, 2013 7:57 am
Added Video list support
New view for videos
Bluetooth notifications are now optional
Bluetooth album art is now optional and off by default
Bluetooth album art is now 300 px instead of 500 px when enabled
Fixed swipe to change track on album art
archrival
UltraSonic 1.2.0.2
Fix null duration for songs
archrival
Return to UltraSonic for Android
