TheIceMaster wrote:French translation, "Récemments écoutés" appears twice for 2 different menu items which should be:
"Most Played" = "Plus écoutés"
"Recently Played" = "Récemment écoutés" (no "s" at the end of Récemment)
More of a minor annoyance than a bug. In the "Now Playing", long press on a song. If you "Remove Song" it automatically scrolls back to the top which is fine for a small playlist but, if you want have a long playlist and wanted to remove 2-3 songs in the same area, it leads to lots of manual scrolling when, ideally, it could/should stay within the removed song area (should be relatively easy using the list's index) unless this is working like this by design?
pioneersohpioneers wrote:I've had this for a while, but anytime I take out my headphones without pausing music, my phone plays ~1second of the song I was listening to from the speaker, about 3 seconds after I unplug. dunno if this is an ultrasonic bug or janky 4.2.x rom i'm running.
archrival wrote:pioneersohpioneers wrote:I've had this for a while, but anytime I take out my headphones without pausing music, my phone plays ~1second of the song I was listening to from the speaker, about 3 seconds after I unplug. dunno if this is an ultrasonic bug or janky 4.2.x rom i'm running.
I have noticed the same behavior, I will look into it.
pioneersohpioneers wrote:archrival wrote:pioneersohpioneers wrote:I've had this for a while, but anytime I take out my headphones without pausing music, my phone plays ~1second of the song I was listening to from the speaker, about 3 seconds after I unplug. dunno if this is an ultrasonic bug or janky 4.2.x rom i'm running.
let me know if I can help in anyway.
pioneersohpioneers wrote:Minor bug:
I just queued up an album I needed downloaded to my phone for my ride home, and noticed that the Server is reporting i'm listening to the song that is downloading, rather than the song that is paused on my phone.
mr_nobody wrote:Yeah, pretty sure that's a server side thing over which the client has no control...
ThaRappa wrote:Hey archrival,
Thanks for the great app! Not sure how recently this started occuring, but every so often when I try to pin/download songs it looks like the app gets caught in a loop of deleting the file and then trying to redownload. I can see the action on the server page cycling through, but the file doesn't actually get saved to the phone. When I click on the file to stream it, it can play with no issues, it just doesn't seem to want to save. Not sure if the issue is the app, the rom, or just something crazy.
Background:
HTC One (rooted rom)
Attempting to Download over Wifi
Logcat from the phone has been supplied, but let me know if I can provide anything else.
Thanks for the hardwork you've put into this app, I use it almost everyday.
Return to UltraSonic for Android
