Feature Requests for UltraSonic
Discussion for the UltraSonic App for Android
Re: Re: Feature Requests for UltraSonic
Postby archrival » Thu May 30, 2013 6:41 am
mttmllns wrote:Just stumbled on this app in the market. Looks great! Definitely hope to switch from the default Subsonic app but there's one tiny thing holding me back:
I just got a Pebble smart watch and noticed artist/track/album metadata isn't showing up on the watch. It should look something like this:
This works with the default Subsonic app and most other music apps. Apparently you need to send the metadata via AVRCP. I found the following stackoverflow guidance:
http://stackoverflow.com/questions/15527614/send-track-informations-via-a2dp-avrcp
Would love if you could add this! I can test any builds you make. Aaaand I just realized you have this up on GitHub, too, so if you don't get around to it maybe I'll submit a pull request one of these days. :)
Cheers!
That was working, it must have broken in the last few builds. I will look into fixing it. I just need to find something I can test it with.
archrival
Postby svrds10 » Thu May 30, 2013 8:53 pm
Drashna wrote:
archrival wrote:
Drashna wrote:Would it be possible to add a play speed setting?
I use subsonic mainly for podcasts and audiobooks, and that would make it so much easier on me. Especially as I make sure I cache entire sections before leaving home.
I am not sure what you mean exactly, can you explain in more detail please?
Sent from my HTC6435LVW using Tapatalk 2
To be able to increase the playback rate. Such as 1.5x or 2x speed. That way I can listen to files/tracks in half the time.
+1 on this feature. It would definitely be awesome when listening to podcasts :)
svrds10
Postby mttmllns » Thu May 30, 2013 11:31 pm
archrival wrote:That was working, it must have broken in the last few builds. I will look into fixing it. I just need to find something I can test it with.
Odd...it's intermittently working. Let me do some more investigation and I'll see if I can get some reliable repro steps.
mttmllns
Postby oshogg » Fri May 31, 2013 7:43 pm
Could you please look into integrating MX Player (like the official Subsonic client app did recently)? I really love UltraSonic and do not wish to switch to Subsonic?
Osho
oshogg
Postby archrival » Fri May 31, 2013 8:37 pm
oshogg wrote:Could you please look into integrating MX Player (like the official Subsonic client app did recently)? I really love UltraSonic and do not wish to switch to Subsonic?
Osho
Already done, will be in the next release.
archrival
Postby Drashna » Fri May 31, 2013 8:57 pm
svrds10 wrote:
Drashna wrote:To be able to increase the playback rate. Such as 1.5x or 2x speed. That way I can listen to files/tracks in half the time.
ArchRival's already said that it's not supported by the music player. So may not be possible with the android app, sadly.
However, once it's downloaded/cached, you should be able to a different media player to do that.
Osho
Awesome!
Drashna
Postby archrival » Fri May 31, 2013 11:32 pm
Osho
Awesome!
There are a number of third party libraries that have support for playback speed adjustments, I may consider adding them at some point, but I cannot guarantee anything.
archrival
Postby fivestones » Sat Jun 01, 2013 2:48 pm
I would also really, really appreciate a playback speed setting so i can listen to audiobooks at higher than normal speed
fivestones
Postby TheIceMaster » Sun Jun 02, 2013 5:49 pm
In the "Now Playing", long press on a song, would it be possible to add "Go to Artist" also?
Settings -> Cache Location is currently is a text box when you have to type an exact location. Could it be a file/directory browser instead to select the location? I agree that this is low priority and only useful when moving the cache to an external sd card but it would make it easier rather then having to type a case sensitive path such as "/storage/extSdCard/ultrasonic".
PS: Awesome app! :)
TheIceMaster
Postby archrival » Sun Jun 02, 2013 7:07 pm
TheIceMaster wrote:In the "Now Playing", long press on a song, would it be possible to add "Go to Artist" also?
PS: Awesome app! :)
Go to Artist is on my to do list. I am just debating how I should go about it. It is much easier to accomplish with confidence with ID3 tag browsing. Otherwise the top level folder could be an artist or not depending on your file layout.
I will look into the file browser, I agree it makes more sense.
archrival
Postby fossiliensammler » Tue Jun 04, 2013 5:27 pm
Hi archrival,
i want to cross fade between the songs. did this function works in your app?
thx joern
fossiliensammler
Postby Andy L » Wed Jun 05, 2013 8:10 am
Is there any possibility of being able to reorder songs in the play queue in future?
Andy L
Postby jefish » Sun Jun 16, 2013 5:02 am
I use Ultrasonic in the car, DC powered, almost exclusively. There's almost never a time I want the screen to sleep automatically during playback.
Request for a permanent "Prevent Screen Off" or "Prevent Sleep" (or whatever the general Android terminology is) in Settings. This would work in concert with the "Screen On" toggle during playback.
If the user leaves the new Prevent Sleep switch disabled in Settings (default), the Screen X toggle reads "On." User can tap this toggle as s/he does now to temporarily keep the screen on. Toggle state resets on next app start to echo opposite of Settings switch.
If the user enables Prevent Sleep in Settings, the Screen X toggle reads "Off." User can tap this toggle to temporarily allow the screen to sleep. Toggle state resets on next app start to echo opposite of Settings switch.
jefish
Postby Stupifier » Mon Jun 24, 2013 1:47 pm
I have a simple and effective request for change/modification:
Issue
When scrolling through the currently playing playlist, it is difficult to find the actual currently playing song. The only identifying mark is the play symbol next to the song on the list (which is the same color as the rest of the text). This is very troublesome when you have a rather large playlist playing.
Easy Solution
Have the currently playing song in the list stand out by highlighting the song tile background a different color (say ICS blue or something). This way with a quick thumb flip through the currently playing list, anyone should be able to know where their currently playing song is. The color would stand out in the list and it would be extremely easy to spot even while scrolling quickly.
Stupifier
Postby Stupifier » Thu Jun 27, 2013 4:18 pm
Does Ultrasonic cache the folder structure of a server? If not, I believe this would greatly increase the ability to quickly browse through the music collection on a server.
Think about it this way....whenever you open a folder in ultrasonic, you see these messages roll by:
1. "Contacting Server....please wait"
2. "Reading from server"
Those messages occur everytime you open a folder....regardless of previous opens...and sometimes have hangups. This behavior is redundant, network dependent, and not optimal in my opinion. The solution would be to have ultrasonic cache the folder structure of a server. This would mean there would only be a one-time contact/read to the server for each folder (unless a change/addition to folder structure obviously).
Maybe Ultrasonic already does this caching behavior....and the above messages are just checking for changes and not asking for redundant data. If so, fantastic....that means Ultrasonic already caches.
Stupifier
Return to UltraSonic for Android
