pioneersohpioneers wrote:Quick bug, in 3.9.9.20 (maybe earlier),
If you rotate the screen with "Starred Songs" loaded from the Server/Recently Added/Played etc tab (left most, don't know how to refer to the square of squares), the page reloads. Minor, but I thought I'd point it out.
Other than that, this version runs really well on my Rezound (4.2.1, w/ proxystream) and my NookTablet (4.2.1, haven't streamed yet).
Drashna wrote:BlueTooth controls have the "old" ICS issue.
Namely, pause/play doesn't work. Stop, next, previous all work, but won't pause or resume.
I'm running ViperOneS, on my HTC One S (Android 4.1.1, Sense 4+), BT is LG HBS700.
archrival wrote:pioneersohpioneers wrote:Quick bug, in 3.9.9.20 (maybe earlier),
Yep. I see that. I will add that to my list.
Sent from my HTC6435LVW using Tapatalk 2
KicknGuitar wrote:Just began using this badboy today. I love the slight adjustments from the standard Subsonic. I'd love to see gapless happen too.![]()
Unfortunately, subsonic keeps starting up on its own. Here's two logs:
https://www.dropbox.com/s/3w7u20qynqgm6 ... t%2001.txt
https://www.dropbox.com/s/rb9ydpciwp2l1 ... t%2002.txt
Is this something I can fix on my end?
Cheers.
pioneersohpioneers wrote:I wonder if this has anything to do with subsonic not actually exiting when you choose menu -> exit. That functionality is more like a restart.
cofulese wrote:Great app. Any chance of adding the ability to delete locally cached content from any level, like artist folder, album folder, etc...
Cheers
KicknGuitar wrote:pioneersohpioneers wrote:I wonder if this has anything to do with subsonic not actually exiting when you choose menu -> exit. That functionality is more like a restart.
I never used menu-exit. I just use the back button.
I did try the exit from menu just now but it seems to only change views/windows not actually close subsonic.
as a temp workaround for the exiting thing, i have noticed that if you pull the notification drawer down and press the stop button on the widget, subsonic will close.GrindheadJim wrote:KicknGuitar wrote:pioneersohpioneers wrote:I wonder if this has anything to do with subsonic not actually exiting when you choose menu -> exit. That functionality is more like a restart.
I'm having the same issue, also the dreaded "host name cannot be null" error (which had a fix in another build here). Any workarounds?
rubbersoul wrote:as a temp workaround for the exiting thing, i have noticed that if you pull the notification drawer down and press the stop button on the widget, subsonic will close.
Return to UltraSonic for Android
