perd_ok wrote:Hey thanks for the great work on this app. I'm loving it so far. The feature I'm most enamored by isthe random song feature. However, I can't seem to get it to function properly since the first day I used it. Most of the time I receive a "No media found" message. Now, when it does work, it only seems to pull titles from one of my Media Folders (and, unfortunately, not the one I want). I'm using the current public Madsonic fork. Verizon GS3 stock rooted. Perhaps not a bug, but user error. Any suggestions?
archrival wrote:Which server do you happen to be using? I have noticed similar behavior with Madsonic but not with the official Subsonic server.
perd_ok wrote:archrival wrote:Which server do you happen to be using? I have noticed similar behavior with Madsonic but not with the official Subsonic server.
Hey thanks for checking this out. I'm using Madsonic 4.8 beta 3.
ezraghast wrote:Hi, i'm still seeing the strange behaviour of play album next in 1.1.0.17- playback begins immediately and shuffles tracks.
ezraghast wrote:Many thanks, as always.
pescuma wrote:One bug happens quite often for me: when offline, when I play an album the music doesn't start. It adds the album to the play list but the first song is displayed as "Downloading - 0 B". I had previously installed the default client and downloaded some albums. Later, I found your version and downloaded some albums with it (both use the same folder). The albums downloaded with the default client works fine. Albums downloaded with UltraSonic presents this problem.
archrival wrote:pescuma wrote:One bug happens quite often for me: when offline, when I play an album the music doesn't start. It adds the album to the play list but the first song is displayed as "Downloading - 0 B". I had previously installed the default client and downloaded some albums. Later, I found your version and downloaded some albums with it (both use the same folder). The albums downloaded with the default client works fine. Albums downloaded with UltraSonic presents this problem.
Any chance you could try the latest version and let me know if this is still happening? I can't reproduce it.
pescuma wrote:archrival wrote:pescuma wrote:One bug happens quite often for me: when offline, when I play an album the music doesn't start. It adds the album to the play list but the first song is displayed as "Downloading - 0 B". I had previously installed the default client and downloaded some albums. Later, I found your version and downloaded some albums with it (both use the same folder). The albums downloaded with the default client works fine. Albums downloaded with UltraSonic presents this problem.
Thanks for trying to fix the problem. I tried with the latest version and the problem still exists. I tried the following steps:
1. Uninstalled
2. Deleted folder
3. Installed
4. Configured a server and downloaded one album
5. Went offline
6. Played the album
And it shows the "Downloading - 0 B"
Also, I have to mention that I'm using latest version of MusicCabinet (I don't know if this changes anything).
Return to UltraSonic for Android
