CarSub V7 now available - search, random + more
An iOS Subsonic Client
Postby rich600 » Wed Jan 21, 2015 9:26 pm
Hi all,
I'm pleased to announce that CarSub V7 is now available.
Version 7 of CarSub has the following new features:
- Full Search of your Subsonic music collection
- Play random albums
- Play random songs
- Play highest rated
- Play most frequently played
Tweaks:
- Ability to cancel the buffering/loading view (tap view to cancel)
- For SubSonic v5.1 and above, you can chose whether anything in the Get Albums... section comes from the current music folder, or all your music
Bugs fixed:
- Loading spinner now shows when selecting Playlist
- Change of play/pause on remote control when Carsub is in the background will correctly update the icon on Now Playing
- Streaming bug on old Subsonic versions fixed
V8 is underway - I've already added an ID3 Tag mode and Last.FM integration + more tweaks and fixes.
Cheers
Rich.
rich600
Re: CarSub V7 now available - search, random + more
Postby NoahJenda » Sun Jan 25, 2015 8:20 pm
Rich,
Thanks for your continued progress on your app. It's just getting better and better.
Any progress with gapless playback? It was still about the same the last time I tested it. It's still not quite seamless.
Keeping my fingers crossed that this might be something coming up in a future version.
NoahJenda
Postby rich600 » Mon Jan 26, 2015 5:19 pm
thanks for the feedback.
I looked into the micro-gap, and I've posted an issues on the project Wiki, but I've got no response from the developer. I created a stand-alone app that demonstrated the problem, so it should be simple to replicate.
There have been some changes in the library that have yet to be incorporated into CarSub, and I will be moving those into the app in the future.
Cheers
Rich
rich600
Postby newpower » Thu Feb 05, 2015 11:56 pm
I really like the interface.
Too bad cache is not working for me.
newpower
Postby avbudin » Fri Feb 06, 2015 3:00 am
Could you please add random from folder? For example I have my families collection sorted into master folders. I'd like to be able to press random, then select the folder and have it create a random playlist on the fly and start playing.
avbudin
Postby rich600 » Sun Feb 08, 2015 12:47 pm
Hi
when you say cache is not working, could you tell me what problems you've got and I can take a look at them.
What OS version you're running and what device?
Rich
rich600
Postby newpower » Tue Feb 10, 2015 1:36 pm
rich600 wrote:Hi
Rich
I was able to cache an album, then I tried to cache a playlist and nothing happened. I don't know if relevant, but the playlist contain one song from the album I was able to download along with other songs. When I check the playlist in the cache section it only shows one song (the one included in the downloaded album).
I'm using iOS 8.1.3, iPhone 6
newpower
Postby rich600 » Fri Feb 13, 2015 2:48 pm
Thanks for the info.
It sounds like it didn't download the playlist at all. The reason it shows the 1 song is because it recognized that it already had it in the downloaded album, so it reuses that rather than duplicate the song and waste valuable cache space.
I'll take a look at the scenario.
Cheers
Rich
rich600
Return to AVSub
