AVSub 11.1 is out
An iOS Subsonic Client
AVSub 11.1 is out
Postby rich600 » Mon Jul 27, 2015 1:08 pm
Hi all,
AVSub 11.1 is now available.
V11 is concentrating on a UI refresh, with 11 & 11.1 bringing improvements to the following screens
- Now playing
- Cache
- Main menu
- Media Index
In the media index, you can now switch between letters or the actual long list of all artists.
All views have new graphics which are optimized for both 2x and 3x retina screens.
Also, iPad gets a size appropriate view, balancing screen real-estate with size.
I'm currently working on 11.2, which will bring refreshed UI for general folder browsing.
You can download AVSub here - https://itunes.apple.com/gb/app/avsub/id923424694?mt=8
Thanks for your continued support.
Rich
rich600
Re: AVSub 11.1 is out
Postby krushr » Tue Jul 28, 2015 6:02 pm
As noted in the other post - after either upgrading or a fresh install the UI on a 6 PLUS shows no menu items so you cant navigate or do anything after the last update.
krushr
Postby rich600 » Tue Jul 28, 2015 9:38 pm
Thanks for the info.
What version of iOS are you using?
What happens if you rotate to landscape?
I don't have 6 Plus. but in the 6 plus simulator it's ok.
Rich
rich600
Postby Failed Engineer » Wed Jul 29, 2015 3:43 am
I'm having the same issue on a 6, running iOS 8.1. AVSub 10 worked fine, and I haven't made any changes to the phone since.
Hope you can figure it out. 11 looks fantastic!
Failed Engineer
Postby rich600 » Wed Jul 29, 2015 6:14 pm
Hi
I wonder if the issue is iOS8.1?
I can only test on 8.4 or 7.3, the latest versions of the OS versions that Apple supports.
Can you upgrade?
Cheers
Rich
rich600
Postby krushr » Thu Jul 30, 2015 12:25 am
Have the issue with 8.4 here.
krushr
Postby rich600 » Mon Aug 03, 2015 8:31 am
sorry for slow response - mega busy at work & home!
If you're having issues, can you send me your email address to issues[at]avsubapp[dot]co[dot]uk.
I'll create a debug version and add you as a tester so we can get to the bottom of this weird bug!
Cheers
Rich
rich600
Postby stanthewizzard » Sun Aug 16, 2015 9:36 am
I'm using it for the first time from isub ...
Great job
BUT you need help for the french translation !
You want some ?
stanthewizzard
Postby rich600 » Tue Sep 08, 2015 9:04 pm
thanks for the offer of help with the French translation - any corrections you can send over I will change in the app.
If you post them here, I'll pick them up.
Thanks a lot!
Cheers
Rich
rich600
Postby rich600 » Tue Sep 08, 2015 9:05 pm
Hi all,
the problem that a couple of you have been having in 11.1 is fixed in 11.2.
Thanks to my beta testers for all their help!
Cheers
Rich
rich600
Postby NoahJenda » Wed Sep 09, 2015 6:53 pm
Rich,
Any chance that AVSub might support FLAC files on the iPhone? So far, the only iOS app that will let me play FLAC files is iSub. I seem to remember that iSub uses a different music player, which is how it can support FLAC. I much prefer the UI for AVSub, so I'm hopeful it's something you might be able to do eventually.
NoahJenda
Postby rich600 » Sun Sep 13, 2015 11:57 am
Hi
I'd love to add FLAC support but AVSub uses a 3rd party audio API that doesn't support it.
However, I'm going to look at other options for FLAC very soon. iSub uses a different audio library to AVSub, and it's not free. The licensing cost is prohibitive, so I'm afraid I can't use that one.
Rich
rich600
Postby NoahJenda » Fri Oct 09, 2015 7:56 pm
Rich,
Glad to know FLAC support is on the roadmap!
For now, I'll continue to use iSub when I want to listen to my FLAC files, but I much prefer AVSub's UI and features so I look forward to a future upgrade when I can use AVSub for everything.
NoahJenda
Return to AVSub
