V18 is out - enhanced views
An iOS Subsonic Client
Postby rich600 » Wed Sep 21, 2016 6:46 pm
Hi all,
V18 of AVSub is out now and can be downloaded here - https://itunes.apple.com/uk/app/carsub/id923424694?mt=8
V18 adds the following new features:
- New enhanced view for browsing your media in folder mode. Artists are recognised and presented with artist artwork and biography, albums, top songs and similar artists. Choose whether this appears all the time or just on WiFi, plus other configuration options. This is a great way to rediscover artists in your collection.
- New suggestions component right on the front screen. See what's new, what's been listened to recently and what's popular. Play direct from the front screen with a single tap. The number of items is configurable too.
- Trigger a refresh of the Subsonic folders from within Settings
- Control over more UI colours using a colour picker
- Small UI tweaks to tidy up a few things
- Various bug fixes
I tried to add features that took advantage of the data you can get from AVSub to enrich the experience. I'll be looking to further take advantage of this sort of related data in future releases too.
On the website, I've added the AVSub tips to the FAQ page (which is now the tips/FAQ page) - see http://www.avsubapp.co.uk/faqs.html
V19 is underway and hopefully there won't be such a big gap this time :-)
Cheers
Rich
rich600
Re: V18 is out - enhanced views
Postby TwitterBot » Thu Sep 22, 2016 8:55 pm
Is it possible to disable the suggestions component?
I can't see the configuration area for it in the settings section.
TwitterBot
Postby rich600 » Thu Sep 22, 2016 9:21 pm
Hi
currently it's tied to the "enhanced information view" also - disable one, disable both.
I'll differentiate in the next release.
[Update] DONE
Cheers
Rich
rich600
Postby theorego4 » Fri Sep 23, 2016 12:32 pm
Hi Rich,
V18 is not recognizing my prior "Video" upgrade purchase?
Theo
theorego4
Postby rich600 » Fri Sep 23, 2016 3:14 pm
does the app not allow you to play videos (you get the popup) or has the video button just disappeared from the front screen (this is toggled in the settings).
Have you tried "restore purchases" in the Help/About page?
Cheers
Rich
rich600
Postby theorego4 » Sat Sep 24, 2016 1:54 pm
rich600 wrote:Hi,
Cheers
Rich
Thanks Rich! Can't believe I missed the "restore purchases!" You know the old saying - "If it was a snake ...."
Theo
theorego4
Return to AVSub
