Skips in music playback
Re: Skips in music playback
Postby BKKKPewsey » Wed Sep 19, 2012 12:07 pm
Check with netstat and make sure nothing else is trying to use the same port.
I assume that its only SS that is affected and all other streams are ok as a flaky router could cause those symptoms.
Postby wiobyrne » Wed Sep 19, 2012 3:22 pm
I restarted the router (AT&T 2wire) and reinstalled basic Subsonic (4.7 (build 3106))...jetty-6.1.x, java 1.6.0_27, Windows 7
I checked netstat and nothing seemed to pop up that seemed abnormal. I pasted the log in a dropbox file, available here: https://www.dropbox.com/s/0wu4rsnzsnuh9i3/netstat.txt
I letting it run for today to see if it settles down. I experienced some skips earlier, but will check throughout the day. I'm also thinking about moving my backup of the library back into the music library I use for Subsonic. I just want to see if there are problems with the music tracks that are causing this. I tested it by playing them in Windows Media and Media Monkey and didn't notice anything, but I saw that there might be glitches in the tracks themselves that other music player sort out. I may have had some issues as I moved over from Ubuntu to Windows.
If that doesn't work, I'll try going back to Ubuntu to see if that'll make a difference.
wiobyrne
Postby wiobyrne » Tue Sep 25, 2012 11:51 am
After a ton of searching...and a lot of help from Gary and Hakko...
I think I got it figured out. It primarily was (embarrassingly enough for me) a reinstall of the network card drivers for Windows 7. I also reinstalled java and flash on the host computer.
Thanks again all.
wiobyrne
Previous
