[solved]W2k8Srvr Media folder not found with non local drive
Re: Win2k8Server - Media folder not found with non local dri
Postby Psyclone » Fri Jan 18, 2013 11:52 pm
Ok, I just got it sorted out and it was authentication related but not in the way that I thought, and unless I missed something not in the way that the FAQ's address or touch on. It does look like the Subsonic service passes it's credentials to the shared resource and that shared resource must be able to authenticate against the passed credentials. Despite configuring the service with the Administrator account and synchronizing the Administrator account passwords between the two machines it was not working. What finally did the trick was to use an account that is in the Administrators group(but not the actual Administrator account) with synchronized passwords. I was in fact previously using identical accounts however the passwords were not synchronized. Once I went to the Windows 7 box and changed the account password to match that identical account name that is on the server, it kicked in and worked.
This restriction was in place and seems to contradict the postings I read that state that 'if you can access(via My Computer/Windows Explorer) the remote network shares from the machine where Subsonic is installed and configured then the media folders should be good to go'. Since I had granted 'Everyone' full access to the shared folders on the Windows 7 box, and since I can access the network shares without entering any credentials I would have thought it would all have worked. If this is covered in the FAQ then I missed it and perhaps it should be highlighted. I'm pretty savvy when it comes to networking/windows configuration and I struggled with this for a bit longer than I should have IMO.
At any rate I'm up and running.
Psyclone
Postby GJ51 » Sat Jan 19, 2013 1:33 am
Yeah, I can't remember where I picked up on that one, but the service account credentials used have to be identical valid credentials on both the SS host and the share being accessed.
You know MS - anything to make it more difficult. :wink:
Re: [solved]W2k8Srvr Media folder not found with non local d
Postby bionicdude » Sat Jan 26, 2013 11:41 am
+1 for this.
I'm running on windows8 64bit.
I have sambashares on my ubuntu server that i'm trying to connect to.
no method of entering the share address was working.
Then i read psyclone's comment and got it sorted.
I created a new LOCAL account and gave it the user/pass that had access to the shared folder (incidentally, this was the same user/pass that i was logging into the subsonic server with).
I then edited the subsonic service to use this new user as the logon user (so it's running in the context of that user).
Now everything works.
I would suggest that this is a bad way to set things up. It would be better if users could tell subsonic what credentials to use for each share. Just my two pence...
And thanks for the feedback psy...saved me some time (like you, I'd already spent too long on this).
bionicdude
Previous
