Resolved: Can't Connect
still NOT working
Postby JusWannaJAM » Sun Feb 10, 2013 11:17 pm
last step tried went to canyouseeme.org on port 4040 still couldn't see me however when i go directly to http://YOURNAME.subsonic.org i can see my page etc.. :twisted:
JusWannaJAM
Re: still NOT working
Postby JusWannaJAM » Sun Feb 10, 2013 11:20 pm
or go here to see whast i've already been doing or tried
viewtopic.php?f=2&t=11402
JusWannaJAM
Postby alphawave7 » Mon Feb 11, 2013 12:42 am
JusWannaJAM wrote:last step tried went to canyouseeme.org on port 4040 still couldn't see me however when i go directly to http://YOURNAME.subsonic.org i can see my page etc.. :twisted:
When you do this, are you on a device/computer INSIDE your lan/wlan...if so, your router is transcribing the subsonic.org into a lan routable IP (your server's IP), and is NOT a test nor verification your port is open. You'll still need to get your router's manual, and get 4040 open, tested and verified with canyouseeme.org, before it will work for outside clients. :)
edit: for hardware version 2 of that router:
http://homedownloads.cisco.com/download ... 86_Web.pdf
"To set up single port forwarding for multiple ports:
Applications & Gaming > Single Port Forwarding
1. Make sure that the software you want to use has been installed onto a
networked computer .
2. Log into the browser-based utility (see “How to open the browser-based
utility” on page 25) .
3. Set up DHCP reservation for the IP address of the computer on which
you installed the software . (See “How to set up the DHCP server on your
router” on page 29) .
4. Click the Applications & Gaming tab, then click the Single Port
Forwarding page .
5. For each entry, enter a descriptive name in the Application name field .
6. For each entry, enter in the same port number for the External Port and
the Internal Port .
7. In the To IP Address field, enter the last three digits of the IP address you
have reserved for the computer you want to forward Internet traffic to .
The rest of the IP address has already been completed for you
8. Select Enabled next to the IP Address field .
9. Click Save Changes at the bottom of the screen .
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:39 am
SO WHAT AM I SUPPOSED TO DO HERE?
JusWannaJAM
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:43 am
i logged into my browser based utility and it looks nothing like that anymore..
i am using the linksys smart wifi app or whatever now
so the link you put in is no longer going to help me
I also know nothing about port forwarding or the DHCP reservations or whatever
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 2:44 am
JusWannaJAM wrote:SO WHAT AM I SUPPOSED TO DO HERE?
Is your router a version 1 or 2? I think the instructions above should do it..
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:45 am
version 1 but the instrustions no longer look like that now as i upgraded my firmware on my router the other day
JusWannaJAM
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:47 am
just to let you know the cpu i am using now is the same one i will have subsonic on, it is also wired into the router i am using
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 2:50 am
Okay...it looks like you may have an 'Advanced Routing' tab when you log in...I'm still looking for a pic of this...but this is likely the tab we need to get it to pass 4040 for the server IP...
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:52 am
here follow this link and this is what it looks like now
http://homesupport.cisco.com/en-us/support/ccc
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 2:52 am
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:53 am
thats what the left pane look like when i log into my router
JusWannaJAM
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:54 am
yes!
But what do i do now???
JusWannaJAM
Re: Can't Connect
Postby alphawave7 » Mon Feb 11, 2013 2:55 am
JusWannaJAM wrote:thats what the left pane look like when i log into my router
Yeah..it's the Security tab we need...
Re: Can't Connect
Postby JusWannaJAM » Mon Feb 11, 2013 2:55 am
i'm logged into my router now
JusWannaJAM
Users browsing this forum: Google [Bot] and 35 guests
