ssl certificate in namecheap.com help me please(solved)
Re: ssl certificate in namecheap.com help me please
Postby beaver944 » Mon Mar 18, 2013 4:10 pm
hakko wrote:Are you aware that different browsers have their own sets of trusted CAs, and that if your CA is not chained to one of the pre-installed ones, you manually have to tell your browser to start trusting it (verifying fingerprints yourself)?
I bought an SSL certificate from Comodo, i must have no error with the web browser
beaver944
Postby beaver944 » Mon Mar 18, 2013 4:28 pm
I have 3 files at namecheap.com alias Comodo:
AddTrustExternalCARoot.crt PositiveSSLCA2.crt t411-wiki_me.crt
beaver944
Postby beaver944 » Fri Mar 22, 2013 11:52 am
I solved my problem, I use a proxy apache :D .
https://t411-wiki.me/subsonic/
beaver944
Re: ssl certificate in namecheap.com help me please(solved)
Postby Aethies » Fri Mar 22, 2013 1:16 pm
I am using the standalone version of subsonic on Ubuntu server.
This is what I did to install the cert:
There are four commands that needed to be run.
1. Combine the certs together into one file (there are multiple ways to do this, I chose the easiest way in linux)
cat private.crt servercert.crt intermediate.crt > echo subsonic.crt
2. Convert the cert from PEM to PKCS12 so java can use it.
openssl pkcs12 -in subsonic.crt -export -out subsonic.pkcs12
3. Create Java keystore
keytool -importkeystore -srckeystore subsonic.pkcs12 -deskeystore subsonic.keystore -srcstoretype PKCS12 -srcalias 1 -destalias tomcat
4. Import the keystore into the jar file
zip /var/subsonic/standalone/subsonic-booter-jar-with-dependencies.jar subsonic.keystore
Start subsonic and you should be good to go!
One very important thing to note: When asked for a password for the keystore or keys, use subsonic as the password. Any other password used and it will fail on starting subsonic.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby beaver944 » Mon Mar 25, 2013 12:15 pm
Hello
Thank you very much it works very well Aethies :D.
beaver944
Postby aweber1nj » Fri Apr 26, 2013 2:04 pm
Has anyone tried these steps with 4.8?
I have tried a number of permutations of this, but it does not pick-up my SSL Certificate. After restart, I browse to the subsonic app and the certificate still shows the subsonic.org one.
Any other ideas?
-AJ
aweber1nj
Postby aweber1nj » Fri Apr 26, 2013 4:25 pm
This was my fault.
Best thing to do is copy the keystore to the same directory where your jar is, then run the zip there (or probably the OP works, but you can't specify). Basically, what happened to me is adding a path (relative or otherwise) in front of the keystore makes zip add that relative path into the JAR -- so the keystore does not replace the subsonic/default one.
If you see "adding..." (incorrect) in response to your zip command in the OP instead of "updating..." (correct), then you need to correct it; it will not work.
Sorry for any confusion, but maybe this will help someone else.
-AJ
aweber1nj
Previous
