Default Upload Directory
Postby aphuey » Sat May 02, 2009 3:56 am
Yeah, I figured you might have some other content in G:\Music that you didn't want indexed and shared.
What I meant was to add G:\Music\Incoming as a 2nd Shared folder. That way, the G:\Music\Incoming folder is seen by Subsonic, but not any of the other content in the G:\Music folder (except G:\Music\MP3's).
aphuey
Postby VintageGold » Sat May 02, 2009 4:12 am
Now I'm feelin' ya. I tried what you suggested and it worked! :D In the Subsonic settings I now have these two folders, the second added as you suggested:
G:\Music\MP3's
G:\Music\Incoming
In the code I used:
<td><input type="text" id="dir" name="dir" readonly="true" size="37" value="G:\Music\Incoming"/></td>
and that did the trick! I hope this helps others who are trying to do the same thing. 8)
Thought of the Day: They say the best things in life are free, but are all free things the best?
VintageGold
Postby bstrdsmkr » Sat May 02, 2009 10:01 pm
I'd fathom a guess that this is bc subsonic only lets you access folders that you have "given permission" to (added as a share).
bstrdsmkr
Postby mixmaster » Mon May 04, 2009 9:33 pm
aphuey wrote:Yeah, I figured you might have some other content in G:\Music that you didn't want indexed and shared.
Yes, uploading is not allowed outside of defined directories. You can filter the tree view now based on those folder.
________
mixmaster
Re: Default Upload Directory
Postby beehlerj » Mon Feb 27, 2012 6:09 am
Has anyone been able to figure this out because I would like them to be loaded into a folder that automatically loads files into iTunes.
Also is there a way that i can limit what kind of files can be uploaded i.e. exe
beehlerj
Previous
Users browsing this forum: No registered users and 44 guests
