denney wrote:I just experienced this problem with 3.7 beta 1 on Ubuntu 9.04. I'd say it was due to an unclean reboot of the computer which caused the database to become corrupt.![]()
Deleting the "db" folder and running Subsonic again fixed the problem. I've taken a backup of the "db" folder after setting all the settings again to safeguard against this next time.
utbluesman wrote:First, have to say, great application.
Have been using 3.5beta1 and it's really quite good. Well done.
The server has been running 3.5beta1 for a week or more now without issue.
Suddenly, today, I get.
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
[2011-04-08 23:42:08,395] INFO DaoHelper - Checking database schema.
[2011-04-08 23:42:08,579] INFO Schema25 - Database table 'version' not found. Creating it.
[2011-04-08 23:42:08,579] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:36)
at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:107)
at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:64)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
Caused by: java.sql.SQLException: User not found: SA
at java.sql.DriverManager.getConnection(DriverManager.java:620)
at java.sql.DriverManager.getConnection(DriverManager.java:169)
... 76 more
[2011-04-08 23:42:08,814] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sat Apr 09 03:00:00 CEST 2011
[2011-04-08 23:42:11,940] INFO NetworkService - Successfully forwarding port 4040.utbluesman wrote:Just as a heads up, I ended up uninstalling the Beta, then crawling through the registry deleting all references to Subsonic, then deleting c:\subsonic as well.
After a reboot, I reinstalled the Beta and all works well.
Not the prettiest solution, but it's up and running.
Thanks for the quick response.
Again, very cool application.
# chown -R subsonic:subsonic /var/subsonic
