Error browsing into non-latin subfolders
Postby sindre_mehus » Mon Feb 12, 2007 2:24 pm
Thanks for sending the MP3 examples.
Is there any particular reason you don't let the Subsonic web interface auto-start WMP with the proper URL?
If you for whatever reason need to enter the stream URL manually, you can specify which player to use by adding a "player" parameter, for instance:
http://localhost:8080/subsonic/stream?player=1
Hope this helps,
Postby d2master » Tue Feb 13, 2007 11:25 am
i'm moving my questions about streaming to this thread (it seems more related to the subject)
http://forum.subsonic.org/forum/viewtopic.php?t=406
________
Honda SL90 specifications
d2master
Still problems in 3.1
Postby dozer » Wed Aug 01, 2007 7:10 pm
Hi there,
I had this same NullPointer-exception problem when using Subsonic 3.0. Then I followed the forums instructions and upgraded to Subsonic 3.1. Well, the problem is still there. I get the same NullPointer-exeption for frames left.view and top.view
this is the exception:
java.lang.NullPointerException at net.sourceforge.subsonic.domain.MusicFile.getChildren(MusicFile.java:208) at net.sourceforge.subsonic.service.MusicFileService.getChildDirectories(MusicFileService.java:135) at net.sourceforge.subsonic.domain.MusicIndex.getIndexedChildren(MusicIndex.java:189) at net.sourceforge.subsonic.controller.TopController.handleRequestInternal(TopController.java:30) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:45) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:820) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:755) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:396) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:350) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at javax.servlet.http.HttpServlet.service(HttpServlet.java:802) at sun.reflect.GeneratedMethodAccessor46.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:517) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:161) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:245) at org.apache.catalina.core.ApplicationFilterChain.access$0(ApplicationFilterChain.java:177) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at sun.reflect.GeneratedMethodAccessor50.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:517) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:217) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain.access$0(ApplicationFilterChain.java:177) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:25) at sun.reflect.GeneratedMethodAccessor49.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:517) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:217) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain.access$0(ApplicationFilterChain.java:177) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:36) at sun.reflect.GeneratedMethodAccessor48.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:517) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:217) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain.access$0(ApplicationFilterChain.java:177) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:36) at sun.reflect.GeneratedMethodAccessor47.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:517) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:217) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain.access$0(ApplicationFilterChain.java:177) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Thread.java:619)
OS: Ubuntu Feisty 7.04 (using unicode)
Tomcat: 5.5
Java: 1.6
Subsonic 3.1
dozer
Postby dozer » Thu Aug 02, 2007 7:08 pm
I think i have tried about everything now...
but the same exception keeps coming and coming again.
I have tried to put the LC_ALL=en_US to the tomcat startup-script
I have tried to put the LC_ALL=en_US.UTF-8 to tomcat startup-script
I have tried to recode my music filenames from windows encoding to UTF-8.
I have tried to recode my music filenames from UTF_8 to ISO-8859-1.
And all the combinations of above. Each time I have deleted and recreated the /var/subsonic -folder.
What I dont wanna do is to put the LC_ALL=en_US to my default locale, because I have other software which uses the UTF-8 encoding. And I don't even think it would help because none of the above worked either.
What sucks most is that I don't even know which file/folder causes the problems! (So I could remove id) I have many many songs which have 'weird' characters...
Please help!
dozer
Postby sindre_mehus » Sun Aug 05, 2007 10:06 am
Hi dozer,
Sorry to hear about your problem. I think this is a different error than the one discussed earlier in this thread. That error was related to character encoding of URLs, and was fixed in 3.1.
Now, the error you're seeing is slightly different (but probably also related to directories with "funny" characters). For the next version I will make Subsonic more fault-tolerant so that it skips directories which it is unable to read (and logs a proper warning message).
Cheers,
Previous
