not authorized to perform the request
Postby jigsaw » Tue Mar 17, 2009 8:16 pm
Try the following:
locate your applicationContext-security.xml file. It should be located in SUBSONIC\jetty\webapp\WEB-INF\applicationContext-security.xml.
Edit the file and locate this area in the file
    <bean id="filterInvocationInterceptor" class="org.acegisecurity.intercept.web.FilterSecurityInterceptor">
        <property name="authenticationManager" ref="authenticationManager"/>
        <property name="alwaysReauthenticate" value="true"/>
        <property name="accessDecisionManager" ref="accessDecisionManager"/>
        <property name="objectDefinitionSource">
            <value>
                PATTERN_TYPE_APACHE_ANT
                /login.view=IS_AUTHENTICATED_ANONYMOUSLY
                /accessDenied.view=IS_AUTHENTICATED_ANONYMOUSLY
                /stream/**=IS_AUTHENTICATED_ANONYMOUSLY
                /style/**=IS_AUTHENTICATED_ANONYMOUSLY
                /icons/**=IS_AUTHENTICATED_ANONYMOUSLY
                /wap/playerJad.view=IS_AUTHENTICATED_ANONYMOUSLY
                /wap/playerJar.view=IS_AUTHENTICATED_ANONYMOUSLY
                /generalSettings.view=ROLE_ADMIN
                /advancedSettings.view=ROLE_ADMIN
                /userSettings.view=ROLE_ADMIN
                /musicFolderSettings.view=ROLE_ADMIN
                /transcodingSettings.view=ROLE_ADMIN
                /internetRadioSettings.view=ROLE_ADMIN
                /searchSettings.view=ROLE_ADMIN
                /podcastSettings.view=ROLE_ADMIN
                /db.view=ROLE_ADMIN
Just for testing purposes add the following line in the list
                /db.view=IS_AUTHENTICATED_ANONYMOUSLY
Restart subsonic and log in again with the admin-user. Now try accessing the db.view URL I gave you earlier.
If it works it basically means that the security mechanisms in Subsonic does not identify the user "admin" as an admin-user.
I tried this myself and it allowed a non-admin user to access the db.view URL.
jigsaw
Postby tezelcelebi » Wed Mar 18, 2009 6:13 am
Hi jigsaw,
last night I tested something different and it worked. The problem is completely related with regional settings and java. In Turkey, machines are set to use TR-tr codepage-language settings. Java still doesnt want to understand this :)
Anyway, I uninstalled Subsonic, changed regional settings to US-en, rebooted machine, re-installed Subsonic and works perfectly now. I can access to any menu item and create users etc.
There is nothing wrong with Subsonic. I am very happy now :D
Thanks you very much for your valuable time.
Regards,
tezelcelebi
Postby jigsaw » Wed Mar 18, 2009 6:55 am
I am glad you figured it out :)
jigsaw
Re: not authorized to perform the request
Postby takarusan » Fri Oct 12, 2012 12:51 pm
tezelcelebi wrote:Hi jigsaw,
Regards,
I'm from Turkey too. I've tried this but it didn't work at all. Sindre could you please fix this issue?
I really love Subsonic, it works in my Ubuntu setup but not in Windows 7/8 because of this...
takarusan
Previous
