CAN'T INDEX MUSIC ON A NETWORK SHARE
samba w/ subsonic
Postby elitenoobboy » Mon Nov 23, 2009 4:21 am
I am using subsonic on ubuntu, and to get samba working, I simply automounted it through nautilus, then for the music folder that I told subsonic to use, I used "/home/username/.gvfs/sharename/music". The directory structure will of course vary depending on what is mounted where, but nautilus mounts smb as normal folders in the .gvfs folder. Worked without any trouble.
Edit: Actually, the flash player doesn't seem to be able to play any of the files in the .gvfs folder, but it is still able to play anything locally just fine. Yet, at the same time, everything including stuff over the network will play when using an external player. Weird. I assume a bug. Does anyone know why this would happen?
elitenoobboy
Previous
