WMA Lossless
Postby mhendu » Wed Oct 27, 2010 5:07 am
I uninstalled Subsonic, renamed my c:\subsonic folder to subsonic.bak and reinstalled the program. However, all of the decoders are set up to ffmpeg, and when I set up wmadec it won't play any WMA files. Any suggestions? Thanks!
mhendu
reinstall
Postby bethesdaadk » Wed Oct 27, 2010 12:48 pm
interesting how your reinstall didn't work. But the symptom you are having is the same thing that happened to me. There must be some reg or ini file left behind that's putting your settings back to this useless transcoder settings instead of what it should be.
I took a snip of my transcoding screen and saved it to a jpg. But I can't seem to find a way to upload it to this message.
If you want to send me a message via this forum, I can try and email it back to you and you can try and type it all in.
bethesdaadk
Previous
