4.1 Upgrade Issue - "Unsupported format"
Postby sindre_mehus » Tue Nov 23, 2010 9:46 am
Postby srobison13 » Thu Dec 02, 2010 8:59 pm
sindre_mehus wrote:Please use the recommended transcoding settings.
I was having a problem with my m4a files not playing (not being transcoded correctly, apparently). After changing my transcoding settings to the sample configuration my files stream fine. Just out of curiosity, why wouldn't my default settings match the recommended ones? In this case my default was:
m4a mp3 faad -w %s lame -b %b -x - -
The recommended (and working) is:
m4a mp3 ffmpeg -i %s -f wav - lame -b %b --tt %t --ta %a --tl %l -S --resample 44.1 - -
srobison13
Postby Peachcake » Tue Jan 11, 2011 9:47 pm
Thank you for the troubleshooting and recommended settings. I was just about to go and convert the few WMA to MP3 so I didn't have this problem (I probably will anyway since I don't have many wma files....old rips from cd's :P). It looks like I didnt have the new transcoder that I added from your recommended transcoding settings checked in the player. thanks a lot!
Peachcake
Re: transcoding settings
Postby muiz » Wed Jun 01, 2011 7:00 am
bpschroder wrote:you will need to change your transcoding settings
[code]cbr:
step 1
wmadec -b 16 %s -
step 2
lame -b %b -r - -
or vbr:
step 1
wmadec -b 16 %s -
step 2
lame -v -b %b -r -
yessssss finaly , this works. thx !!
muiz
Previous
