Hacking Help Wanted: Linux Geek? Apply Within.
Postby Anima79 » Wed Nov 10, 2010 9:10 pm
Hello!
Good to see advancements on your side! I never thought about YT-videos myself, thank you for this advice.
When you want to format a HD with for example ext4, you can use mkfs. Try:
mkfs.ext4 /dev/sdb1
, where sdb1 is again you external HD.
I don't understand exactly what your question is concerning mount :)
Mount is not so different from Windows as it seems to be at the first glance. You just tell debian that a partition of your HD is a folder in the filesystem. What you copy to this folder is written to the HD at once (btw: in Windows you can do the same thing: have a HD act as a folder).
Have fun!
:wink:
Anima79
Re: Hacking Help Wanted: Linux Geek? Apply Within.
Postby La_Tristesse » Sun Mar 04, 2012 7:25 pm
What's about Encryption? Is Subsonic working with a encfs encrypted Ext3?
La_Tristesse
Previous
cron
