Search issues with 4.2 Beta 1
Postby teknojnky » Fri Jan 07, 2011 4:50 am
also using 4.2 final and noticed having many searchs not find stuff I know (and verified) are there (and have good tags).
Version 4.2 (build 1944) – November 21, 2010
Server jetty-6.1.x, java 1.5.0_14, Linux (198.2 MB / 499.6 MB
[1/5/11 11:11:58 PM CST] INFO SearchService Created search index with 213422 entries.
teknojnky
Postby kronos003 » Mon Jan 10, 2011 11:04 am
I'm now on the latest 4.3 non beta. the search engine that was in subsonic had issues but it found stuff. this new search engine is SO !@#@ USELESS i cant use it to search at all - i just better know what I'm looking for and where to find it. with this new search engine, why bother to have a search database at all?
Seriously Sindre, please invest some time to fix this. i know you like your donations. and if you want to keep them coming you may want to fix this feature. Like ive said before, go have a peak in the Amarok camp and figure out how they do searches and implement every trick they are using.
The amarok search engine is SUCH A DREAM TO USE- finding things is EFFORTLESS!!
kronos003
Postby reddwarf » Wed Jan 12, 2011 2:09 pm
I finally upgraded from 4.1 and the search function is completely dead. I get "no matches found" no matter what I search for. Quite a drag, I used that quite a bit.
reddwarf
Postby mamekedi » Sun Jan 23, 2011 2:27 pm
today i installed Latest beta release – Subsonic 4.4.beta1
the search function is still shit ! why don't u fix it.
OLDER INFO:
Dirname:
F:\MP3\MP3-049
Album that doesn't show at a search:
Frans Duijts - Zo Ben Ik Mezelf (2008) dir F:\MP3\MP3-049
Example: first filename:
01 Komt Er Voor Mij Dan Ook 'n Dag.mp3
Album that does show at a search:
Frans Duijts - Denken Dat je Alles Mag (2008) dir F:\MP3\MP3-049
01 Jij Denkt Maar Dat Je Alles Mag Van Mij.mp3
Tip!
When i browse at the left side of the screen (subsonic in browser) at directorie MP3-049
i can see the albums that doesn't show up in the search function.
Everthing works oke in version 4.1!
Again !!!
mamekedi
Postby stozher » Sun Jan 23, 2011 3:51 pm
Send me this file :wink:
stozher
Postby kroken » Sun Jan 23, 2011 4:47 pm
Anyone experience this problem? this happens on 4.2-4.4
http://forum.subsonic.org/forum/viewtop ... highlight=
you should get things working first before starting on new projects, like the movie feature.
kroken
Postby kroken » Fri Feb 11, 2011 4:22 am
Bump
kroken
Postby InShaneee » Tue Feb 15, 2011 8:42 am
I've had a lot of issues with search as well in recent updates. Particularly when adding large amounts of music, then clicking 'update search index now' doesn't seem to actually update the search index (once the update is complete, the new songs still do not show up in search, even after refreshing the browser window). Sometimes, I'm finding that manually updating the search index is even going so far as to crash the SubSonic service.
Edit: I've just tried rebuilding the index from scratch, and it does pick up all the music I added recently, so I doubt it could be an issue with the music itself.
Edit2: Added some more music and manually updated the index, and the new stuff still isn't showing up in searches.
Edit3: I checked my logs, and found this:
[2011-02-15 22:56:18,437] INFO SearchService - Updating Lucene search index.
[2011-02-15 22:56:23,484] ERROR LuceneSearchService - Failed to create Lucene search index.
java.lang.OutOfMemoryError: Java heap space
at org.apache.lucene.index.TermsHashPerField.rehashPostings(TermsHashPerField.java:522)
at org.apache.lucene.index.TermsHashPerField.add(TermsHashPerField.java:442)
at org.apache.lucene.index.DocInverterPerField.processFields(DocInverterPerField.java:93)
at org.apache.lucene.index.DocFieldProcessorPerThread.processDocument(DocFieldProcessorPerThread.java:246)
at org.apache.lucene.index.DocumentsWriter.updateDocument(DocumentsWriter.java:826)
at org.apache.lucene.index.DocumentsWriter.addDocument(DocumentsWriter.java:802)
at org.apache.lucene.index.IndexWriter.addDocument(IndexWriter.java:1998)
at org.apache.lucene.index.IndexWriter.addDocument(IndexWriter.java:1972)
at net.sourceforge.subsonic.service.LuceneSearchService.createIndex(LuceneSearchService.java:93)
at net.sourceforge.subsonic.service.SearchService.doCreateIndex(SearchService.java:159)
at net.sourceforge.subsonic.service.SearchService.access$000(SearchService.java:60)
at net.sourceforge.subsonic.service.SearchService$1.run(SearchService.java:113)
InShaneee
Postby InShaneee » Tue Feb 22, 2011 12:09 am
Going on info from another thread, I tried deleting both the index file and the Lucene folder entirely, then allowing both to regenerate. After restarting Subsonic, the index completed successfully, but when I added a new album and forced a refresh of the index, it again failed as described above.
FYI, I'm running this on Windows Home Server.
InShaneee
Postby stozher » Tue Feb 22, 2011 1:55 pm
Increase memory...
stozher
Previous
