schitonk wrote:you're not getting an ip from dhcp. if youre connecting through a router make sure dhcp is enabled and that the router is what connects to your modem to get out to inet.
mech259 wrote:I have always had a static route to the SS server. I can change the port on my setup and try that. I don't understand why the current setup with port 80 worked for about a week just fine then quit working.
mech259 wrote:I never thought it had anything to do with SS. I was trying to solve my local problem. Well, did a workaround and put the 169.xxx ip addy as a secondary IP and now it works.
