[Solved] JWPlayer - Video not found or access denied
Postby baje » Sun Feb 13, 2011 6:32 am
I have exactly the same problems.
.mp4 and .mov works fine but .avi or .mkv doesn't work with SD or HD video. I try all the line i can see here but none are working for me...
Somebody know one thing i can try ?
Edit : It seems, nothing work but the player can play some file without transcoding. But when he try... =>
[13/02/11 07:49:12 CET] INFO StreamController Got range: Range[0,9223372036854775807]
[13/02/11 07:49:12 CET] INFO PlaylistInputStream ********* listening to "Musique/*****.avi"
[13/02/11 07:49:56 CET] INFO StreamController Got range: Range[0,39038]
[13/02/11 07:49:56 CET] INFO PlaylistInputStream ******** listening to "Musique/*****.mkv"
Edit 2 :
[13/02/11 07:53:51 CET] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/home/*****/Musique/*****.mkv] [-async] [1] [-b] [1000k] [-s] [480x360] [-acodec] [libfaac] [-v] [0] [-f] [flv] [-]
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.6-4:0.6-2ubuntu6, Copyright (c) 2000-2010 the FFmpeg developers
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Oct 5 2010 22:36:53 with gcc 4.4.5
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --extra-version=4:0.6-2ubuntu6 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 50.15. 1 / 50.15. 1
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 52.72. 2 / 52.72. 2
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 52.64. 2 / 52.64. 2
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 1.19. 0 / 1.19. 0
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 0.11. 0 / 0.11. 0
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) [matroska @ 0xe86420]Estimating duration from bitrate, this may be inaccurate
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, matroska, from '/home/*****/Musique/*****.mkv':
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Metadata:
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) doctype : matroska
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) title : *****
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:44:03.32, start: 0.000000, bitrate: 384 kb/s
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
[13/02/11 07:53:51 CET] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Unknown encoder 'libfaac'
And i can't find libfaac package on ubuntu :/
baje
Previous
