replace SSL cert (Ubuntu)
Postby humvee » Thu Feb 24, 2011 10:44 pm
@hogfan
I tried:
keytool -import -alias root -keystore mysubsonic.keystore -trustcacerts -file privateAndCert.key
and
keytool -import -alias root -keystore mysubsonic.keystore -trustcacerts -file onlyCert.crt
and
keytool -import -alias tomcat -keystore mysubsonic.keystore -trustcacerts -file onlyCert.crt
on every action i have to enter a password, I always typed "subsonic" as password, I have to put a word longer than 6 chars in.
but both doesn't work :/
i can't access subsonic on https port (my port settings are correct), :/
thx,
greetings,
humvee
humvee
Postby seanpkeown » Mon Feb 28, 2011 1:20 am
Give Portecle a try. Its a gui for the java keytool and might make it easier when creating and importing certificates.
http://portecle.sourceforge.net/
seanpkeown
Postby humvee » Wed Mar 16, 2011 12:51 am
Now I've downloaded that tool and did:
- New keystroke
- JKS
- Tools
- Import Trustet Cert
I tried both variants:
1:
-----BEGIN RSA PRIVATE KEY-----
theKey
-----END RSA PRIVATE KEY-----
-----BEGIN CERTIFICATE-----
theCert
-----END CERTIFICATE-----
and 2:
theCert
in the first example i named the key in the keystore: "tomcat" and in number two i named it like my server-host.
then i saved the keystore. pwd was subsonic.
after that I can't connect to http and https.
but the log of subsonic says that the sockets (ssl and non-ssl) started correctly.
now i have no idea where the problem could be :/
the jar file has the owner root and the chmod 755
tanks for your answers.
humvee
Re: replace SSL cert (Ubuntu)
Postby karrth » Mon Feb 03, 2014 9:59 pm
Solution on Debian:
1) stop subsonic
service subsonic stop
2) Backup the jar file as well:
cd /usr/share/subsonic/
cp subsonic-booter-jar-with-dependencies.jar subsonic-booter-jar-with-dependencies.jar.bak
3) extract the subsonic.keystore:
jar xf subsonic-booter-jar-with-dependencies.jar subsonic.keystore
4) Remove the current cert in the keystore:
keytool -delete -alias subsonic -keystore subsonic.keystore
5) add your crt to the keystore, replace "mydomain.crt" with your crt filename. Password when prompted is "subsonic":
keytool -import -trustcacerts -alias subsonic -file mydomain.crt -keystore subsonic.keystore
6) Add the keystore back into the jar file:
jar uf subsonic-booter-jar-with-dependencies.jar subsonic.keystore
7) Boot up Subsonic again
service subsonic start
You might want to keep a copy of the keystore somewhere for easy re-insertion when you upgrade Subsonic.
Helpful links:
viewtopic.php?t=5295
http://www.sslshopper.com/article-most- ... mands.html
http://docs.oracle.com/javase/tutorial/ ... pdate.html
http://docs.oracle.com/javase/tutorial/ ... npack.html
karrth
Previous
