Android subsonic unable to connect to server
Postby GJ51 » Thu Apr 21, 2011 2:13 pm
Does the phone work with other servers, such as the demo server?
Postby GJ51 » Thu Apr 21, 2011 2:32 pm
Does it work on the demo site?
Postby eazolan » Fri Apr 22, 2011 1:13 am
woah, it does work with the demo site!
So, does the Android app use a different port than doing this through the web or something?
eazolan
Postby GJ51 » Fri Apr 22, 2011 1:54 am
You have to set up your server so that it's accessible from the internet by opening the port that SS uses on your router and forwarding it to the server that hosts SS.
I think I may have posted those instructions somewhere on this site once or twice :wink: before ...
Postby eazolan » Fri Apr 22, 2011 3:40 am
hm. I had set up port forwarding on my router manually. And it worked fine for the web browser but not the android subsonic client.
I deleted that rule, and saw that the server already had UPnP turned on.
The Android client worked after that.
Maybe UPnP and the manual rule I made were conflicting somehow?
eazolan
Postby GJ51 » Fri Apr 22, 2011 6:36 am
No matter how many times I try, it just seems inevitable ... so here you go.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby relevelence » Fri Jul 01, 2011 8:38 pm
I have followed the steps from GJ51.
I disabled the "Automatically configure your router to allow incoming connections" within subsonic
I manually setup port forwarding.
I am able to access the server via a web browser, both on a machine outside my network and my phone. When I set up the subsonic app on my phone the test connection passes, but when I try to access my media library from the app, I get a network error occurred.
relevelence
Postby GJ51 » Fri Jul 01, 2011 9:16 pm
Very unusual. Test your phone on my site below and let me know if it works. We first need to determine if it's the phone or your site that is causing the problem.
Postby relevelence » Fri Jul 01, 2011 11:02 pm
It works. I don't know how I can access my server from the standard web browser. I am not using the subsonic.org within the software, so I'm not sure if that's the issiue ?
Any ideas of setting up the android app without the subsonic.org. its just strange how I can access my subsonic sever via a web browser still.
relevelence
Postby GJ51 » Sat Jul 02, 2011 3:20 am
There are a few things you can try. Sometimes clearing the settings on the Android app and redoing them can fix the problem. Sometimes reinstalling the app with a phone reboot in between can help. You can always enter the external ip:port# instead of the Subsonic.org name.
Usually, if you can get access over a browser from outside your network, the Android app will work. Most often when I've seen problems like yours it's due to a typo or an error in the app settings. If you still have problems and you'd like me to test your server, just send me a pm with a guest logon credential.
Previous
