alphawave7 wrote:Then use the DLink as router and bridge the Linky to the lan. IIRC, broadbandreports forums has a Linksys bridging tutorial, so google that. Report back when you can!
disgustipated wrote:youre working on different subnets, youre not going to be able to see the other boxes connected to the linksys from the public network
try plugging an ethernet from the dlink into one of the switch ports of the linksys rather than the wan. it might act as just a switch and the linksys wont try to assign different ip addresses
glancing at your other posts it seems like youre trying to use the linksys as a repeater gateway so you dont have to run wires. if thats the case look in to using dd-wrt firmware and using repeater bridge mode under wireless settings. i dont think the stock firmware offers this sort of functionality. I have a wireless router in my home downstairs connected to the modem and another wireless router upstairs that feeds an ubuntu box and a printer and i am able to forward ports to those boxes.
disgustipated wrote:The trick is using repeater bridge mode in the linksys to connect to the other ssid of the router connected to the modem. I'm out of ideas if that doesn'twork since I have that same setup
GJ51 wrote:Sound like you're almost there!
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
-Airwave- wrote:alphawave7 wrote:Air..I'm accessing your SS on port 80.
not sure how thts possible seeing as i dont have it on port 80? lol
