help with android client
Postby GJ51 » Fri May 27, 2011 12:31 am
Iwould try to setup the phone with the external IP:port# to see if it's just the redirect service that hasn't been updated yet. Did you Go to Settings/Network and resend the servername.subsonic.org info? Also, did you verify that the phone is working on other SS sites, such as the demo site?
Postby DrClaw » Fri May 27, 2011 1:23 am
okay, so apparetnly I can't connect to my own server at all through my android's 3g. But I CAN connect to the test server. I dont see any "resend" button, but it does say "Status: mhersch.subsonic.org responded successfully."
Basically:
-Port 8079 opened and verified through canyouseeme
-can connect to test server
-cannot connect my server on my phone via android client OR html
-my friend was able to connect via html from an outside network
- subsonic was working fine until I physically relocated the router
DrClaw
Postby GJ51 » Fri May 27, 2011 2:09 am
I can get to your login page. If you pm creds I'll test with my phone if you like. I'd suggest clearing and reentering the site in the Android app.
You might also consider a router reboot.
Previous
