Embeding a flash based player
Postby sindre_mehus » Mon Sep 24, 2007 9:10 am
To start the embedded player you have to put something in the playlist and then click "Web player" (in the playlist frame). Did you do that?
As for the javascript error in IE; it's actually IE which doesn't comply to the HTML specification, but I should probably work around it.
Hope this helps,
Postby MaRINoL » Mon Sep 24, 2007 6:41 pm
The curious thing is, I do not see the "web player" option. I am indeed running 3.2.beta1 (build 474)... Sorry for seeming ignorant :(
MaRINoL
Postby sindre_mehus » Tue Sep 25, 2007 6:18 am
No worries :-)
Sometimes the upgrade doesn't work properly. Have you tried to delete the <TOMCAT_HOME>/work directory? (see http://subsonic.sourceforge.net/install.html).
The "Web player" link should pop up next to the "Undo" link whenever the playlist is not empty.
Hope this helps,
Postby MaRINoL » Thu Oct 11, 2007 3:03 am
Sindre-
Thanks very much! That is something I had not tried & did the trick.
I stopped the service, blew away the work directory, restarted & everything was cool.
Thank You for this great software!!
MaRINoL
Previous
Users browsing this forum: No registered users and 44 guests
