Cant find localhost
Re: Cant find localhost
Postby ytechie » Mon Jan 02, 2012 10:03 pm
Untick it, and then enter "http://127.0.0.1:8080". The subsonic org is the subsonic.org address. Your address is prc56.subsonic.org. If you have subsonic running with the port set to 8080 and https off, it will work after typing "http://127.0.0.1:8080" on the server.
The firewall won't block your own computer from accessing itself.
ytechie
Postby prc56 » Tue Jan 03, 2012 9:04 am
After a little more trial and error I seem to be up and running now.
Thanks to both of you for your help.
prc56
Postby ytechie » Tue Jan 03, 2012 9:46 am
No problem! Can you tell us more about what happened? How did you get everything to work?
ytechie
Previous
