Album Art Not Showing
Re: Album Art Not Showing
Postby GJ51 » Mon Apr 30, 2012 4:26 pm
First, On the MAC, in system prefs / SHARING / FILESHARING / OPTIONS.... turn on SMB...
Check to see if it works. If not try using
smb://192.168.2.100/SharedFolder/ - change the ip to whatever your frive is on, then edit the Subsonic service to use a logon that has read/write permissions on the MAC drive.
You will very likely see a performance hit as the drive uses a different file system than Windows NTFS.
Finally, if that doesn't work try this:
http://www.tannerwilliamson.com/2009/09 ... samba-smb/
Postby billkamp » Mon Sep 02, 2013 10:20 pm
My album art was not showing. I saw that /tmp had no space left. rm /tmp/*, restart subsonic, and the art started showing.
billkamp
Previous
