Some FLACs won't play [Resolved]
Re: Some FLACs won't play [Resolved]
Postby evil666 » Fri Sep 13, 2013 8:36 pm
skidelo wrote:I was having this issue as well, except my problem tag was different.
It was the METADATA_BLOCK_PICTURE tag in my case. Also, some problems I ran into:
1) Make sure you have flac installed. (sudo apt-get install flac)
2) Put the .flac in quotes ('.flac')
Note: The find function is automatically recursive.
So my fix was:
find . -name '*.flac' -exec metaflac --remove-tag=METADATA_BLOCK_PICTURE '{}' \;
I love you.... this worked. Been super pissed for about a week now trying to figure this out. Sticky this or something specially if its a known issue for flac transcoding.
evil666
Postby gogogo » Tue Aug 23, 2016 2:27 pm
on raspbian where i have compiled from the source the ffmpeg for arm device, this command not works.
find: `metaflac': No such file or directory
any help?
gogogo
Previous
