International Characters
Postby FlyingSaucrDude » Wed Oct 31, 2007 7:43 pm
So, just to recap:
Subsonic/everything is running on a linux box, and the file with the "é" in its filename is on the same linux box, on the same disk as linux/subsonic/etc.
Here's what works:
* Playing the song directly on the linux box (e.g. opening up VLC, and using it to open and play the song w/out any interaction w/subsonic)
* Playing the song directly on a Windows box (e.g. opening up VLC on the Windows box, and using it to open and play the song, which is accessed via a samba share, w/out any interaction w/subsonic)
* Playing any song with "normal" characters in its path/filename, using subsonic, on the linux box
* Playing any song with "normal" characters in its path/filename, using subsonic, on a windows box
What doesn't work:
* Playing the song w/the "é" directly on the linux box, using subsonic
* Playing the song w/the "é" on the windows box, using subsonic
So yeah...maybe it is some weird Java interaction thing...if I could get more debug info out of subsonic (or even step through its code) that would help a lot...
FlyingSaucrDude
Postby mbo030 » Thu Nov 15, 2007 11:45 pm
Same problem here.
I can't index any international characters on my Ubuntu 7.10, Tomcat 5.5, Java 1.6.0_03.
Does anyone have any idea?
Btw.: Subsonic rocks!
mbo030
Postby mbo030 » Fri Nov 23, 2007 8:35 pm
Problem solved with subsonic 3.3.beta1
Btw: I forgot to mention that the filesystem is FAT on a Truecrypt encrypted HDD
mbo030
Postby FlyingSaucrDude » Fri Nov 30, 2007 8:01 pm
Just in case anybody else ever has similar problems, it turns out my problem was caused by how I transferred the music to my linux box. In particular, I used rsync to copy it over from a Windows system, and that somehow didn't copy the filenames in a way that linux liked.
By booting my windows box into linux, and then mounting my windows partition using ntfs-3g, I was able to scp the music over to the linux box, and now subsonic works just fine...
So it wasn't a subsonic issue, or a java issue, or a linux issue...it was a Windows issue. Figures. :roll:
Still, thanks to everyone who tried to help!
FlyingSaucrDude
Postby pgawel » Wed Sep 17, 2008 2:30 pm
I've solved a similar problem on my system. Look here: http://forum.subsonic.org/forum/viewtop ... =2972#2972
pgawel
Previous
