Java 1.7 Incompatibility
Re: Java 1.7 Incompatibility
Postby sindre_mehus » Tue Aug 07, 2012 8:52 am
gillespam wrote:Hi Sindre,
I also have trouble with Subsonic 4.7b1-3 and Sun Java 1.7.0.5
Please find enclosed a zip file with the two errors I got.
I have no problem at all with the same Java and Subsonic 4.6 FYI.
subsonic.err.zip
Are you deploying subsonic.war on Tomcat? If so, you must clean the "work" directory in Tomcat, as per the install instructions.
Hope this helps,
Postby gillespam » Tue Aug 07, 2012 9:09 am
Hello Sindre,
Clearing the cache was my solution.
Here is what I did each time I wanted to upgrade Subsonic :
- stop the tomcat6 service
- delete everything subsonic related in /var/lib/tomcat6/webapps
- copy there the new subsonic.war
- restart the tomcat service
Thanks for reminding me to RTFM :lol:
gillespam
Postby Mindpaint » Tue Aug 07, 2012 5:41 pm
Just loaded 4.7.beta3 (build 3081) on WHS. All is again perfect.
Mindpaint
Postby GJ51 » Tue Aug 07, 2012 7:11 pm
Mindpaint wrote:Hello all.
What is the final status of this issue (java.lang.IllegalArgumentException - Message:Comparison method violates its general contract!) I assume we are waiting for a new release that fixes the issue?
Any idea on a release date?
Thank You all for everything. Subsonic is Fantastic!
I've installed/upgraded to 4.7b3 3 times on different Windows platforms without any java issues. I thought this was fixed in 4.7b3.
EDIT: Cross posted - glad to see it's working.
Postby btamxx » Fri Aug 17, 2012 7:43 pm
Thanks for all the tips.
I had the latest version of SS beta with J6 and then Java sent an upgrade to J7. SS quit. I un-installed SS, un-installed J7, rebooted, installed SS which also installed J6, and it all works fine. It was absolutely J6/SS compatability.
btamxx
Postby robw » Thu Sep 06, 2012 7:36 pm
Hello all,
Have a problem with java too.
Updateted to the latest subsonic
No album pictures anymore, and can play songs
This is my log output:
Exception
java.lang.NullPointerException
Message
null
Java version
Sun Microsystems Inc. 1.6.0_26
Operating system
Linux 2.6.32-42-server
Server
jetty-6.1.x
Memory
Used 42 of 130 MB
Stack trace
at net.sourceforge.subsonic.service.SecurityService.getMusicFolderForFile(SecurityService.java:238)
at net.sourceforge.subsonic.service.SecurityService.isInMusicFolder(SecurityService.java:233)
at net.sourceforge.subsonic.service.SecurityService.isReadAllowed(SecurityService.java:201)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:98)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:79)
at net.sourceforge.subsonic.controller.NowPlayingController.handleRequestInternal(NowPlayingController.java:54)
at org.mortbay.jetty.servlet
There are a lot more of these errors.
What can be the problem?
Greetz,
Rob
robw
Postby kyomi7502 » Tue Sep 11, 2012 6:38 pm
I was just curious if this was still an issue? If so I'll just leave my java alone. (I think my SS is running off 6u33 currently and the most up-to-date java atm is 7u7).
Also, Rob.. I see the first entry in the trace is (SecurityService.java:238). I'm not an expert or anything but it sounds like it has something to do with permissions?
kyomi7502
Postby GJ51 » Tue Sep 11, 2012 8:54 pm
No problem on Windows using the WAR version. I've been using the latest Java available for some time now without any issues.
Postby mrbellow » Tue Sep 25, 2012 9:15 pm
What's this?
Is this a Java related problem?
I encounter this problem only in one directory of my ReadyNAS where the music is stored
What to do?
Thanx
Exception
org.springframework.dao.TransientDataAccessResourceException
Message
PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version
Sun Microsystems Inc. 1.6.0_20
Operating system
Linux 2.6.37.6.RNx86_64.2.4
Server
jetty-6.1.x
Memory
Used 102 of 183 MB
Stack trace
org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:135)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:125)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:202)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:178)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:84)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
... 62 more
mrbellow
Postby hakko » Wed Sep 26, 2012 6:06 am
I think you should report this to Sindre. Personally, I wouldn't use HSQLDB for storage, but that's a pretty drastic recommendation.
MusicCabinet developer
hakko
Postby mrbellow » Wed Sep 26, 2012 6:35 am
Thank you!
Moreover now I can navigate my files but I can't play them (any format).
The log is :
Error
Exception
Message
null
Java version
Operating system
Server
jetty-6.1.x
Memory
Used 137 of 183 MB
Stack trace
at net.sourceforge.subsonic.service.SecurityService.getMusicFolderForFile(SecurityService.java:227)
at net.sourceforge.subsonic.service.SecurityService.isInMusicFolder(SecurityService.java:222)
at net.sourceforge.subsonic.service.SecurityService.isReadAllowed(SecurityService.java:190)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:95)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:76)
Thanx for any help
mrbellow
Postby hakko » Wed Sep 26, 2012 8:29 am
Another e-mail to Sindre, I'd say. There's no easy configuration (that I'm aware of at least), only more painful clean reinstalls.
hakko
Postby mrbellow » Wed Sep 26, 2012 5:03 pm
What do you mean with " a clean reinstall"?
Is there any particular procedure to make a clean reinstall?
mrbellow
Postby hakko » Wed Sep 26, 2012 6:04 pm
I mean removing the previous database, including user settings etc. If you remove all previous traces of Subsonic and install again, you should be fine. See this post first, though: viewtopic.php?f=6&t=10338
hakko
Postby nohart » Sun Oct 28, 2012 5:01 pm
Is this going to ever get fixed? It says that Java is a security issue so every time I get the latest version it breaks Subsonic. I mean come on and fix it already. I always have to roll back Java...
nohart
