HTTP ERROR 503
Re: HTTP ERROR 503
Postby chrisjx » Fri Sep 02, 2022 5:36 am
First post on this error: 2018 here we are 2022?
We've been busy so have not used it in months but it should still be running. But it is not. Getting a straight up 503
I tried expanding the settings in subsnic.properties as recommended in one of the first posts... no go.
I see no other references to: error in script file line: 14733 java.io.IOException: org.hsqldb.HsqlException: Value too long
It seemed to quit without any changes to the system. It might have cycled during power outage. But I have other servers that have remainedintact. AND this is too similar to other issues I've read in this thread.
What can be done to fix this and improve stability?
I had a subscription for something. Would like of update on that make the system not work? And if so, how would I updte the key without access to the UI?
What's up, subsonic/
Thnks for any tips,
Chris.
Main error:
Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 14733 java.io.IOException: org.hsqldb.HsqlException: Value too long
Distro: Ubuntu 20.04 focal
Welcome to Ubuntu 20.04.1 LTS (GNU/Linux 5.4.0-125-generic x86_64)
System information as of Thu 01 Sep 2022 09:46:31 PM PDT
System load: 0.0
Usage of /: 40.5% of 294.23GB
Memory usage: 5%
Swap usage: 0%
Processes: 137
Users logged in: 0
IPv4 address for ens3: 192.168.0.90
[2022-09-01 16:26:36,412] INFO SettingsService - Java: 1.8.0_342, OS: Linux
[2022-09-01 16:26:36,435] INFO VersionService - Resolved local Subsonic version to: 6.1.6
# update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
0 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 auto mode
1 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 manual mode
* 2 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081 manual mode
Press <enter> to keep the current choice[*], or type selection number:
From the log file:
# tail -n 100 -f /var/subsonic/subsonic.log
[2022-09-01 16:26:33,946] INFO HsqlDaoHelper - Checking database schema.
[2022-09-01 16:26:36,225] ERROR HsqlDaoHelper - Failed to initialize database.
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.hsql.Schema25.execute(Schema25.java:21)
   at net.sourceforge.subsonic.dao.DaoHelper.init(DaoHelper.java:27)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:498)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
   at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:132)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:64)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
Caused by: java.sql.SQLException: error in script file line: 14733 java.io.IOException: org.hsqldb.HsqlException: Value too long
   at java.sql.DriverManager.getConnection(DriverManager.java:664)
   at java.sql.DriverManager.getConnection(DriverManager.java:208)
   ... 74 more
chrisjx
Re: HTTP ERROR 503
Postby chrisjx » Sat Sep 03, 2022 12:51 am
I tried to delete lines 14733 from the script file, I assume subsonic.script, but no effect.
My subsonic.properties file looks like this:
#HSQL Database Engine 1.8.0.5
#Sun Oct 24 03:00:13 PDT 2021
hsqldb.script_format=0
runtime.gc_interval=0
sql.enforce_strict_size=false
hsqldb.cache_size_scale=80
readonly=false
hsqldb.nio_data_file=true
hsqldb.cache_scale=140
version=1.8.0
hsqldb.default_table_type=memory
hsqldb.cache_file_scale=10
hsqldb.log_size=500
modified=yes
hsqldb.cache_version=1.7.0
hsqldb.original_version=1.8.0
hsqldb.compatible_version=1.8.0
What line is too long in the above error?
How do I troubleshoot this. I can't imagine we just re-install without knowing what the problem is. That's the definition of insanity, as the saying goes, doing the same thing but expecting a different outcome...
Please, some clues.
chrisjx
Re: HTTP ERROR 503
Postby zeaklous » Mon Feb 05, 2024 3:58 am
I've been using Subsonic on Windows 10. After a recent PC crash, it's stopped working. Here's the relevant part of the log I believe:
5588 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#f2461' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#f2461' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 71 out of memory
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
I believe the "java.sql.SQLException ... out of memory" part is the key error. It appears multiple times in the startup script.
Any ideas?
zeaklous
Re: HTTP ERROR 503
Postby zeaklous » Fri Feb 09, 2024 3:25 am
I was able to fix my issue! I increased the max memory limit (from 150 to 1500 just to be sure that it would work, haha) and that did the job.
Using the Windows installer you can do this in the Settings panel. On Linux you can pass it in as a command line argument.
zeaklous
Re: HTTP ERROR 503 - possible fix on Linux systems
Postby evilmrb » Tue Sep 08, 2026 1:29 pm
I don't know if this will help anyone because many posts are from years ago. I was a long-term user of Subsonic and I ended up switching to Navidrome. I've tried other things too but always something seemed lacking. Navidrome served me well until weird anomalies started to irritate me a lot. I decided to see if I could get Subsonic working again with the help of ChatGPT.
The most important thing to know is that Subsonic (6.1.6) is bound to Java 8 and won't play nice with more modern versions. Getting my Subsonic installation working again turned out to be simple, although I doubt I would have worked it out myself. If you don't have Java 8 installed - I did - install openjdk-8-jre. Then simply edit the file /etc/default/subsonic and add the location of the Java 8 programs at the bottom of the file. In my case this is : export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64/jre . This tells Subsonic to use the Java 8 installation instead of the system-wide one. The rest of your system still uses the default (later) version of Java. Once I did that, I started the Subsonic service and everything had been preserved. All I had to do was scan my music library to find all the new stuff and it all worked again. I am ecstatic.
It made me realise how well-designed Subsonic is and, despite it being no longer developed, is still the gold standard. I can't find a single thing to criticise. Sindre Mehus did what Leo Fender did with electric guitars - he got it right from the beginning.
evilmrb
Previous
