If another phone has no issues on your site, it would tend to point more toward your phone being the issue.
Same would hold true if you had the same issue on a site that is known to work well.
Without testing, it's all speculation.
sn0skier wrote:No its not speculation. It's thinking.
GJ51 wrote:As I've said, if we can narrow it down to the phone, we then need to get everyone having this issue to post the specific details of their phone so we can look for a common denominator that may be the root cause.
As it stands now, most users with this issue don't even describe the phone they're on when they say they have a problem. It's really hard to suggest possible fixes when there are so few details to go on.
Phone make/model, carrier, OS + ver#, SD card capacity and freespace, and knowing if the phone is stock or rooted with a custom rom would all be helpful to know.
It would also help if the file types affected were listed. Does this happen with all file types? Are there any files that play without problems?
hyatari wrote:If u are using a droid 2, rooted and having skipping issues id recommend trying squidlys rom. He must have done something with stagefright/opencore or some kind of audio tweaks cause the problem has vanished for me. It also fixed lastfm stuttering while scrolling thru anything with a big list on my phone. I asked him what he tweaked and waiting for a response. Anyhow I installed this one here : http://www.droidforums.net/forum/droid- ... lblur.html
He has a different version here as well : http://www.droidforums.net/forum/droid- ... icial.html
lame -S -h --resample 44.1 -b %b --tt %t --ta %a --tl %l %s -ffmpeg -i %s -f wav -lame -b %b --tt %t --ta %a --tl %l -S --resample 44.1 - -lame -b %b --tt %t --ta %a --tl %l -S --resample 44.1 %s -parlance wrote:
Skips about 10 seconds into the song which is about 80kb worth of actual data, the progress indicates by this point it has downloaded over 500kb generally, so it has nothing at all to do with data not having been received.
