Java 1.7 Incompatibility
Re: Java 1.7 Incompatibility
Postby GrindheadJim » Thu Mar 21, 2013 7:41 pm
For anyone not keen on navigating Oracle's archives, here's a reliable, clean source for java 6:
http://www.oldapps.com/java.php
GrindheadJim
Postby ameyers » Tue Mar 26, 2013 2:40 am
I'm having this same problem with Subsonic 4.7 on Win8 x64 as of yesterday after updating Java. I'll try reinstalling Java and see if that helps but if anyone has any other solutions please post.
ameyers
Postby gaui » Fri Mar 29, 2013 3:45 am
C:\Windows\system32>"C:\Program Files (x86)\Subsonic\subsonic-service.exe" -start
Could not start service. Error code: 5
C:\Windows\system32>java -version
java version "1.7.0_10"
*UPDATE* Updated Java to 1.7.0.17 and reinstalled Subsonic 4.7 and finally got it working! :D
http://java.com/en/download/index.jsp
gaui
Postby siGh » Fri Apr 05, 2013 2:02 pm
Would this incompatibility affect the external player in any way? One day it worked perfectly, the next day it didn't. The page loads, there is a brief flash (excuse the pun) where the player would normally be, and then all that remains are the top and bottom titles.
siGh
Postby highnoon » Fri May 10, 2013 9:20 am
When will this issue be resolved???
What is the best workaround?
Tried to do a downgrade to java 7.17 and subsonic 4.7 but has no affect, still have the same problems!
What are the best alternatives to subsonic?
highnoon
Postby silsurf » Mon Jun 03, 2013 5:17 pm
Is this due to Java 1.7 incompatibility?
HTTP ERROR: 404
/error.jsp
RequestURI=/error.jsp
Caused by:
java.lang.NoClassDefFoundError: net/sourceforge/subsonic/filter/ParameterDecodingFilter$DecodingServletRequestWrapper
at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:51)
Powered by Jetty://
silsurf
Postby rumremix » Wed Jul 10, 2013 7:03 am
Should this thread still be pinned? Doesn't the latest version of subsonic now work with Java 1.7?
rumremix
Postby msujdog » Fri Jul 12, 2013 2:15 pm
Help! What's going on here? Java issue? Both the browser and iPhone app don't work.
Message PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version Oracle Corporation 1.7.0_21
Server jetty-6.1.x
Memory Used 59 of 68 MB
org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:135)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:128)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:154)
at net.sourceforge.subsonic.controller.MainController.getMediaFiles(MainController.java:158)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:68)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
... 62 more
msujdog
Postby msujdog » Sat Jul 13, 2013 4:31 am
Hey all, my problem was a corrupted database, it appears, I removed all media folders and reset everything, then cleaned the database. Upon reinstall, everything works ok.
msujdog
Postby legluondunet » Mon Oct 28, 2013 10:50 pm
msujdog wrote:Hey all, my problem was a corrupted database, it appears, I removed all media folders and reset everything, then cleaned the database. Upon reinstall, everything works ok.
Thank you for this answer, i had same problem.
legluondunet
Postby achmetinternet » Thu Oct 31, 2013 1:45 pm
How did you clean the db without removing the whole installation?
EDIT: this helped
http://wiki.cementhorizon.com/display/C ... c+database
achmetinternet
Postby gfrench » Mon Feb 24, 2014 4:32 am
please add the <blink> tag to this thread ... it has been a long day.
gfrench
Postby slovo » Sun Jul 06, 2014 9:21 pm
I'm running Subsonic 5.0 beta 1 on the latest Java 7 on Windows 7. I have ~3TB of media indexed if it matters...
Today I got 503 SERVICE_UNAVAILABLE from Subsonic's Jetty.
I've recovered from a couple complete failures thanks to the subsonic.script, but this time that file was the right size (over 800kb in my case) but completely full of empty/null characters!
I made a copy of the Subsonic directory in case anyone is interested to debug (Sindre?).
I used an older copy of subsonic.script to get my server operational in the meanwhile..
slovo
Postby Mauro80 » Tue Jan 13, 2015 10:05 pm
Hello all,
today I got the following error message:
HTTP ERROR: 404
/error.jsp
Caused by:
Powered by Jetty://
I am assuming it is related to a corrupt DB. What do you think?
If that is the case, then, how can it be solved? I am running MAC.
thanks!@
Mauro80
Postby quatermass » Sun Apr 26, 2015 7:26 pm
How about archiving this topic guys I mean it's 2015 now!
Stuart Halliday
The Computer Man
quatermass
Previous
Users browsing this forum: No registered users and 41 guests
