HUGE log file
HUGE log file
Postby pderwael » Fri Aug 03, 2012 7:54 pm
Hi all,
I found a huge log file (c:\subsonic\db\subsonic.log - 148Mb) and was wondering if it is safe do delete it, and in this case, what to do in order to avoid wasting disk space like that
Here is a sample of its content
/*C1*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C2*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C3*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C4*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
and it goes on and on...
/*C2605454*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
pderwael
Re: HUGE log file
Postby BKKKPewsey » Fri Aug 03, 2012 10:36 pm
Yes you safely delete it - the easiest way is stop & restart SS which will clear the old log.
That does bring up a good point for all those users who have SS running on a server which is on 24/7.
That log file can grow to quite large size over a period of time - I just checked mine and it was over 360MB in size :shock:
Re: HUGE log file
Postby pderwael » Sat Aug 04, 2012 8:50 am
I've just stopped SS and guess what... the log file is gone!
Every stop/start seems to delete (not just empty) the log file
It might be useful to schedule an auto stop/start every week or so...
Thanks anyway :)
pderwael
