fresh server and android app install => no connection from a
Postby hilavoku » Mon Aug 06, 2012 12:50 pm
Hiho,
together. I installed the current server version 4.6 on a win7 homepremium machine. I can connect over the web interface through the internet and play music. Thats fine. I also installed the android app and entered my server settings. The server test says 'Connection is OK'. I also donated and entered the license. When i try to open the media library from my S3 after ~20 seconds i get a 'A network error occurred.'
I don't know what to change on my my server because the web interface runs just fine.
I looked here in the forum but found a solution.
Can somebody help me?
thx in advance
hila
hilavoku
Re: fresh server and android app install => no connection fr
Postby hilavoku » Mon Aug 06, 2012 4:53 pm
Lol. Did i wrote i've found a solution? :)
Fault on my side. I haven't found a solution. Java Version is 1.6.
When i create i playlist with the web interface over the internet i can see the playlist direct on my Phone but can't play it...
thx
hila
PS: funny thing. On my S3 with Android 4.0.4 i can see the 'recently played' songs and play them but can't connect to the media lib or search songs. Has anyone a hint?
hilavoku
Postby hilavoku » Tue Aug 07, 2012 8:56 am
Okay. I did it. Just installed the latest 4.7 beta and now it works!!! :mrgreen:
hilavoku
