Problem configuration Status : No router found.
Postby Oneig Atyff » Mon Aug 06, 2012 10:43 pm
Hello there,
I've search since 24 hours and can't find anything...
So here is my problem :
I'm using Linux (Xubuntu) and have install Subsonic.
But cannot complete my configuration.
If I check the "using UPnP or NAT-PMP port forwarding" in my router the port forwarding is ok but the http://my_adress.subsonic.org didn't work (connection timeout it said)
If I don't check the bok, setup manualy my IP and open port 4040 and 80 as portforward.com explain me, the http://my_adress.subsonic.org work but I've receiving au "Status : No router found"
After checking the port 4040 is really open but not the port 80.
I don't know what to do, somebody can help me ?
(sorry for my poor english, this is not my native language)
so i've read lately the how to here i can tel :
Problem Description: I can't configure the port forwarding
Troubleshooting Steps: I have try upnp and static IP
Playback Application and version: Standard Subsonic Web Interface
Subsonic Version: 4.7.beta3 (build 3060) – August 2, 2012
Server Version: jetty-6.1.x, java 1.6.0_24, Linux (75.6 MB / 115.5 MB)
Hardware Platform: Linux Xubuntu 11.10
Java Memory Limit: don't know
Last ten log file lines:
[8/7/12 12:22:11 AM CEST]   INFO   DaoHelper   Checking database schema.
[8/7/12 12:22:12 AM CEST]   INFO   DaoHelper   Done checking database schema.
[8/7/12 12:22:13 AM CEST]   INFO   VersionService   Resolved local Subsonic version to: 4.7.beta3
[8/7/12 12:22:13 AM CEST]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Aug 07 03:00:00 CEST 2012
[8/7/12 12:22:13 AM CEST]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Aug 07 00:27:13 CEST 2012
[8/7/12 12:22:18 AM CEST]   INFO   VersionService   Resolved latest Subsonic final version to: 4.6
[8/7/12 12:22:18 AM CEST]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.7.beta3
[8/7/12 12:22:19 AM CEST]   WARN   NetworkService   No UPnP router found.
[8/7/12 12:22:29 AM CEST]   WARN   NetworkService   No UPnP router found.
[8/7/12 12:27:13 AM CEST]   INFO   PodcastService   Starting scheduled Podcast refresh.
Oneig Atyff
Re: Problem configuration Status : No router found.
Postby BKKKPewsey » Mon Aug 06, 2012 11:19 pm
If it is working then you do not have a problem.
You can ignore the router not found message as you are manually forwarding the port.
All that is saying is java cannot find your router in its database for auto port forwarding purposes.
With regard to port 80 you do not need that open as you are using 4040.
(Portforward.com says you do - they are wrong)
Postby Oneig Atyff » Mon Aug 06, 2012 11:39 pm
Ok, thank you !
I've just check after reading your answer with the android apps and it works fine as you say.
This afternoon it didn't work, so I've try several things... It's kind of weird to tel "No router found" when you uncheck the box.
So In fact I finally don't have any problem at all (I only didn't check if it work or not ^^")
sorry for any inconvenience caused.
Oneig Atyff
