NOT OK—LEGACY SOFTWARE
Postby jamdox » Tue Aug 07, 2012 5:57 am
I had a server running on my old PowerMac G4. It had a hard drive problem and I have tried to reinstall with Subsonic 4.0.1, which was previously installed on it. However, the installer has APPARENTLY been updated to ONLY work on 10.5+
I have been using subsonic on this machine for YEARS. DO NOT tell me you only support 10.5+.
DO PROVIDE A SUBSONIC PKG FILE WHICH WILL INSTALL ON OSX 10.4. IT HAS TO BE OUT THERE SOMEWHERE.
jamdox
Re: NOT OK—LEGACY SOFTWARE
Postby hakko » Tue Aug 07, 2012 7:37 am
Why didn't you make backups?
But luckily for you, every single version released since 2.6 is still available. Go grab 4.0 here. http://subsonic.svn.sourceforge.net/vie ... aller-mac/
MusicCabinet developer
hakko
Postby jamdox » Tue Aug 07, 2012 10:29 am
I was actually trying to clone the drive when it quit. Funny thing is, I'm religious about backups for my work machines... :oops:
So, this looks like the resource fork from the old 4.0 installer? Do I need the rest of the code? What do I compile with?
Thanks.
jamdox
Postby hakko » Tue Aug 07, 2012 10:49 am
You'd need the parent directory (http://subsonic.svn.sourceforge.net/vie ... lease-4.0/). Start off by building subsonic-main och subsonic-booter, then build subsonic-installer-mac. From looking at the pom.xml it creates a pkg file for you. You build using Java (I guess you have to get a legacy version of that too) and Maven. Good luck!
hakko
