I can't change this cover art...
Postby an_otter » Tue Aug 07, 2012 3:34 pm
Because it's not a perfect square in size, the image hangs over the links I need to change it (ironically) to one of a appropriate shape. I know this isn't a new bug, but has anyone found a simple solution to this problem?
And the image in question for reference to shape,
http://i.imgur.com/GbyVL.jpg
an_otter
Re: I can't change this cover art...
Postby bushman4 » Tue Aug 07, 2012 4:13 pm
I have.
Open the page in Chrome.
Right Click on the picture and choose "Inspect Element."
A line that starts with "<img src" should be highlighted.
Scroll down in the "Inspect element" screen until you see the next "<div" tag with the grey arrow pointing at it in the left margin.
Click on the grey arrow to open up that "div" section and you will see a link that contains "changeCoverArt.view" in it with a bunch of hex at the end. Click on that link to bring up the "Change Cover Art" screen for the current album.
HTH.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
