need help with subsonic install on Nas4Free
Postby gigaherz » Wed Aug 08, 2012 12:11 am
hi super noob here :-)
I'm running the latest stable release of Nas4Free 9.0.0.1 and I'm trying to install subsonic on it and it's fighting me at every turn. Now it's prob all my fault since i'm strictly a windows user and new to freebsd and all the commands. I read the how-to for freenas which got me as far as I am now. The issue seems to be with java at the moment, just wondering if anyone can help point me in the right direction. I installed the diablo jdk for freebsd7 ok and installed subsonic in /var/subsonic/standalone/. I executed it and I get this error in the subsonic log file.
"Error occurred during initialization of VM Unable to load ZIP library: /usr/local/diablo-jdk1.6.0/jre/lib/amd64/libzip.so"
Now when I had tried to add the dependent packages for most of them it said I already had newer versions, not sure if that matters or if I have to downgrade them somehow to older versions. I looked online for this issue and the fix seems to be in the libmap.conf file but that file doesn't exist on my Nas4free file system I guess since it's a stripped down version of FreeBsd 9. Any help will be greatly appreciated. Thanks.
gigaherz
Re: need help with subsonic install on Nas4Free
Postby gigaherz » Thu Aug 09, 2012 1:46 am
ok I uninstalled the diablo jdk and installed openjdk6 and I finally got it to work. Not sure what the problem was before. hope this helps someone else. :D
gigaherz
Users browsing this forum: Bing [Bot] and 26 guests
