Transcoding fails in 4.7 Beta 3
Postby PieterB » Mon Aug 13, 2012 12:12 pm
Problem Description: After installing 4.7 Beta 3 transcoding for .WMA Lossless to MP3 fails (4.6 already had problems resulting in 'white noise' at the beginning of a track)
Troubleshooting Steps: Checked the transcoding command line: ffmpeg -i %s -acodec libmp3lame -ab 192k -f mp3 -, taken from http://sourceforge.net/apps/mediawiki/subsonic/index.php?title=Transcoders
Playback Application and version: Foobar 2000 1.1.7
Subsonic Version: 4.7 Beta 3
Server Version: jetty-6.1.x, java 1.6.0_33, Windows XP (87.0 MB / 113.4 MB)
Hardware Platform: Windows XP + NASLite network server
Java Memory Limit: 256MB
Some relevant log file lines:
Blue Jamie Myerson The Listen Project.wma':
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Metadata:
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     title           : Sky Blue
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     artist          : Jamie Myerson
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/MediaPrimaryClassID: {D1607DBC-E323-4BE2-86A1-48A42A28441E}
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WMFSDKVersion   : 11.0.5721.5145
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WMFSDKNeeded    : 0.0.0.0000
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     IsVBR           : 1
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/Year         : 1998
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/EncodingTime : 18446744À¹ë? ¶ë?€¹ë?@ºë??
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/UniqueFileIdentifier: AMGa_id=R   347030;AMGp_id=P   182867;AMGt_id=T  1985393
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     composer        : Jamie Myerson
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     publisher       : Sony
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     genre           : Electronica
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     album           : The Listen Project
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     album_artist    : Jamie Myerson
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/Provider     : AMG
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/ProviderRating: 5
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/ProviderStyle: Electronica
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     PeakValue       : 3241
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     AverageLevel    : 5499
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     track           : 1
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Duration: 00:04:12.33, start: 0.000000, bitrate: 844 kb/s
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0.0(eng): Audio: c[1][0][0] / 0x0163, 44100 Hz, 2 channels, 1152 kb/s
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Incompatible sample format '(null)' for codec 'libmp3lame', auto-selecting format 's16'
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Output #0, mp3, to 'pipe:':
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0.0(eng): Audio: libmp3lame, 44100 Hz, 2 channels, s16, 192 kb/s
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream mapping:
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Stream #0.0 -> #0.0
[2012-08-13 14:03:09,875] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Decoder (codec id 86057) not found for input stream #0.0
[2012-08-13 14:03:09,906] INFO PlayQueueInputStream - PieterB listening to "The Listen Project\02 Listen Jamie Myerson The Listen Project.wma"
[2012-08-13 14:03:09,937] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [\\NasLite-11\Disk-2\Music\Jamie Myerson\The Listen Project\02 Listen Jamie Myerson The Listen Project.wma] [-acodec] [libmp3lame] [-ab] [192k] [-f] [mp3] [-]
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   built on Jul 28 2011 01:57:12 with gcc 4.6.1
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavutil    51. 11. 0 / 51. 11. 0
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavcodec   53.  9. 0 / 53.  9. 0
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavformat  53.  6. 0 / 53.  6. 0
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavdevice  53.  2. 0 / 53.  2. 0
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavfilter   2. 27. 3 /  2. 27. 3
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [asf @ 01EBAF40] max_analyze_duration 5000000 reached at 5060000
[2012-08-13 14:03:10,359] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Input #0, asf, from '\\NasLite-11\Disk-2\Music\Jamie Myerson\The Listen Project\02
Changed the transcoding to the recommanded configuration http://www.subsonic.org/pages/transcoding.jsp
These are the resulting relevant log file lines:
What's going wrong?
PB
PieterB
Re: Transcoding fails in 4.7 Beta 3
Postby PieterB » Mon Aug 13, 2012 1:32 pm
Update
Just downloaded & installed one of the latest ffmpeg decoders from http://ffmpeg.zeranoe.com/builds/
Music is loud and clear.
Apparently the decoder which came with the 4.7 install is faulty !
Still want to know if the command line 'ffmpeg -i %s -acodec libmp3lame -ab 192k -f mp3 -' is correct, or that parts can be taken out.
This is part of the log:
Interesting line: ......c:\subsonic\transcode\ffmpeg) PTS 3157, next:3807096 invalid dropping st:0
What's going wrong?
[2012-08-13 15:23:23,796] INFO DaoHelper - Checking database schema.
[2012-08-13 15:23:26,343] INFO DaoHelper - Done checking database schema.
[2012-08-13 15:23:26,875] INFO VersionService - Resolved local Subsonic version to: 4.7.beta3
[2012-08-13 15:23:27,750] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Aug 14 03:00:00 CEST 2012
[2012-08-13 15:23:27,859] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Mon Aug 13 15:28:27 CEST 2012
[2012-08-13 15:23:37,828] INFO NetworkService - Deleted port mapping for port 9988
[2012-08-13 15:23:53,078] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-08-13 15:23:53,078] INFO VersionService - Resolved latest Subsonic beta version to: 4.7.beta3
[2012-08-13 15:24:13,734] INFO PlayQueueInputStream - PieterB listening to "The Listen Project\01 Sky Blue Jamie Myerson The Listen Project.wma"
[2012-08-13 15:24:13,765] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [\\NasLite-11\Disk-2\Music\Jamie Myerson\The Listen Project\01 Sky Blue Jamie Myerson The Listen Project.wma] [-acodec] [libmp3lame] [-ab] [192k] [-f] [mp3] [-]
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) ffmpeg version N-43418-g633b90c Copyright (c) 2000-2012 the FFmpeg developers
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   built on Aug  9 2012 23:52:43 with gcc 4.7.1 (GCC)
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavutil      51. 67.100 / 51. 67.100
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavcodec     54. 51.100 / 54. 51.100
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavformat    54. 22.104 / 54. 22.104
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavdevice    54.  2.100 / 54.  2.100
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavfilter     3.  7.100 /  3.  7.100
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libswscale      2.  1.101 /  2.  1.101
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libswresample   0. 15.100 /  0. 15.100
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libpostproc    52.  0.100 / 52.  0.100
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Input #0, asf, from '\\NasLite-11\Disk-2\Music\Jamie Myerson\The Listen Project\01 Sky Blue Jamie Myerson The Listen Project.wma':
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Metadata:
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     title           : Sky Blue
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     artist          : Jamie Myerson
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/MediaPrimaryClassID: {D1607DBC-E323-4BE2-86A1-48A42A28441E}
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WMFSDKVersion   : 11.0.5721.5145
[2012-08-13 15:24:14,968] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WMFSDKNeeded    : 0.0.0.0000
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     IsVBR           : 1
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/Year         : 1998
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/EncodingTime : 1844674
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/UniqueFileIdentifier: AMGa_id=R   347030;AMGp_id=P   182867;AMGt_id=T  1985393
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     composer        : Jamie Myerson
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     publisher       : Sony
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     genre           : Electronica
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     album           : The Listen Project
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     album_artist    : Jamie Myerson
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/Provider     : AMG
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/ProviderRating: 5
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/ProviderStyle: Electronica
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     PeakValue       : 324
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     AverageLevel    : 549
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     track           : 1
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Duration: 00:04:12.33, start: 0.000000, bitrate: 844 kb/s
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0:0(eng): Audio: wmalossless (c[1][0][0] / 0x0163), 44100 Hz, stereo, s16, 1152 kb/s
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Output #0, mp3, to 'pipe:':
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Metadata:
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TIT2            : Sky Blue
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TPE1            : Jamie Myerson
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WM/MediaPrimaryClassID: {D1607DBC-E323-4BE2-86A1-48A42A28441E}
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WMFSDKVersion   : 11.0.5721.5145
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     WMFSDKNeeded    : 0.0.0.0000
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TCOM            : Jamie Myerson
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TPUB            : Sony
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TCON            : Electronica
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TALB            : The Listen Project
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TPE2            : Jamie Myerson
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TRCK            : 1
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TSSE            : Lavf54.22.104
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0:0(eng): Audio: mp3, 44100 Hz, stereo, s16, 192 kb/s
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream mapping:
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Stream #0:0 -> #0:0 (wmalossless -> libmp3lame)
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Press [q] to stop, [?] for help
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Multiple frames in a packet from stream 0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 974, next:1670902 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 974, next:1670902 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 1113, next:1810219 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 1113, next:1810219 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 1300, next:1949536 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 1300, next:1949536 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 1486, next:2135292 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 1486, next:2135292 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 1625, next:2321048 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 1625, next:2321048 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 1810, next:2460365 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 1810, next:2460365 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 1996, next:2646121 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 1996, next:2646121 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 2182, next:2831877 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 2182, next:2831877 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 2321, next:3017633 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 2321, next:3017633 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 2460, next:3156950 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 2460, next:3156950 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 2647, next:3296267 st:0 invalid dropping
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 2647, next:3296267 invalid dropping st:0
[2012-08-13 15:24:14,984] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 2786, next:3482023 st:0 invalid dropping
[2012-08-13 15:24:15,046] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 2786, next:3482023 invalid dropping st:0
[2012-08-13 15:24:15,046] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 2971, next:3621340 st:0 invalid dropping
[2012-08-13 15:24:15,046] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 2971, next:3621340 invalid dropping st:0
[2012-08-13 15:24:15,046] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) size=      69kB time=00:00:03.70 bitrate= 151.5kbits/s
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 3157, next:3807096 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 3157, next:3807096 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 3297, next:3992852 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 3297, next:3992852 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 3482, next:4132169 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 3482, next:4132169 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 3668, next:4317925 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 3668, next:4317925 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 3807, next:4503681 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 3807, next:4503681 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 3993, next:4642998 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 3993, next:4642998 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 4132, next:4828754 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 4132, next:4828754 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 4318, next:4968071 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 4318, next:4968071 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 4504, next:5153827 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 4504, next:5153827 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 4690, next:5339583 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 4690, next:5339583 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) DTS 4829, next:5525339 st:0 invalid dropping
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) PTS 4829, next:5525339 invalid dropping st:0
[2012-08-13 15:24:15,531] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) size=     112kB time=00:00:05.56 bitrate= 165.0kbits/s
PB
PieterB
Postby BKKKPewsey » Mon Aug 13, 2012 3:46 pm
Have a read of viewtopic.php?f=2&t=9751&hilit=ffmpeg
(All 4 pages :roll: )
I think we have done wma lossless to death and I have run out of popcorn :P
Postby PieterB » Mon Aug 13, 2012 4:18 pm
Update 2
Though transcoding now works fine, opening a cd (play all) takes a lot of time. Also playing the next song from a m3u-play-all download takes way too long. This behavior effects Flac files. WMA files are played instantly.
Part of the log file:
2012-08-13 18:12:04,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) size=    1386kB time=00:00:59.89 bitrate= 189.5kbits/s
[2012-08-13 18:12:07,421] INFO PlayQueueInputStream - PieterB listening to "Only Trust Your Heart\(01) [Jim Tomlinson] Makin' Brownies.flac"
[2012-08-13 18:12:07,437] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [\\NasLite-11\Disk-2\Music\Jim Tomlinson\Only Trust Your Heart\(01) [Jim Tomlinson] Makin' Brownies.flac] [-acodec] [libmp3lame] [-ab] [192k] [-f] [mp3] [-]
[2012-08-13 18:12:08,843] INFO PlayQueueInputStream - PieterB listening to "Only Trust Your Heart\(01) [Jim Tomlinson] Makin' Brownies.flac"
[2012-08-13 18:12:08,843] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [\\NasLite-11\Disk-2\Music\Jim Tomlinson\Only Trust Your Heart\(01) [Jim Tomlinson] Makin' Brownies.flac] [-acodec] [libmp3lame] [-ab] [192k] [-f] [mp3] [-]
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) ffmpeg version N-43418-g633b90c Copyright (c) 2000-2012 the FFmpeg developers
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   built on Aug  9 2012 23:52:43 with gcc 4.7.1 (GCC)
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavutil      51. 67.100 / 51. 67.100
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavcodec     54. 51.100 / 54. 51.100
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavformat    54. 22.104 / 54. 22.104
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavdevice    54.  2.100 / 54.  2.100
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libavfilter     3.  7.100 /  3.  7.100
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libswscale      2.  1.101 /  2.  1.101
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libswresample   0. 15.100 /  0. 15.100
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   libpostproc    52.  0.100 / 52.  0.100
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [flac @ 0232d080] max_analyze_duration 5000000 reached at 5015510
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Input #0, flac, from '\\NasLite-11\Disk-2\Music\Jim Tomlinson\Only Trust Your Heart\(01) [Jim Tomlinson] Makin' Brownies.flac':
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Metadata:
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     track           : 1
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     DATE            : 2000
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TITLE           : Makin' Brownies
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     ARTIST          : Jim Tomlinson
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     ALBUM           : Only Trust Your Heart
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     GENRE           : Jazz
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     COMMENT         : Exact Audio Copy
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     NOTES           : Medieval CUE Splitter (www.medieval.it)
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TOOL NAME       : Media Center
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TOOL VERSION    : 16.0.179
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Duration: 00:05:22.66, bitrate: 743 kb/s
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0:0: Audio: flac, 44100 Hz, stereo, s16
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0:1: Video: mjpeg, yuvj420p, 300x300 [SAR 1:1 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)       comment         : Cover (front)
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [mp3 @ 02323a60] Frame rate very high for a muxer not efficiently supporting it.
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Please consider specifying a lower framerate, a different muxer or -vsync 2
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Output #0, mp3, to 'pipe:':
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TRCK            : 1
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TDRL            : 2000
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TIT2            : Makin' Brownies
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TPE1            : Jim Tomlinson
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TALB            : Only Trust Your Heart
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TCON            : Jazz
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     TSSE            : Lavf54.22.104
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0:0: Video: png, rgb24, 300x300 [SAR 1:1 DAR 1:1], q=2-31, 200 kb/s, 90k tbn, 90k tbc
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)     Stream #0:1: Audio: mp3, 44100 Hz, stereo, s16, 192 kb/s
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream mapping:
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Stream #0:1 -> #0:0 (mjpeg -> png)
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg)   Stream #0:0 -> #0:1 (flac -> libmp3lame)
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Press [q] to stop, [?] for help
[2012-08-13 18:12:09,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:10,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:10,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.7 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:11,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.5 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:11,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.4 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:12,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.3 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:12,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.3 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:13,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.2 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:13,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.2 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:14,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.2 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:14,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.2 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:15,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.2 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:15,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.2 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:16,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:16,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:17,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:17,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:18,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:18,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:19,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:19,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:20,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:20,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:21,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:21,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:22,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:22,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:23,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:23,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:24,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:24,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:25,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:25,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:26,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:26,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:27,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:27,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:28,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:28,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:29,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.1 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:29,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:30,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:30,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:31,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:31,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:32,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:32,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:33,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:33,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:34,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:34,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:35,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:35,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:36,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:36,718] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:37,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:37,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:38,218] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:38,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:39,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:39,703] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
[2012-08-13 18:12:40,203] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) frame=    1 fps=0.0 q=0.0 size=     111kB time=00:00:00.00 bitrate=82837090.9kbits/s
PB
PieterB
Postby BKKKPewsey » Mon Aug 13, 2012 4:49 pm
What happens if you use the SS standard transcode command?
ffmpeg -i %s -ab %bk -v 0 -f mp3 -
Postby PieterB » Mon Aug 13, 2012 5:05 pm
I did try the recommended configuration. I'll try it again to be sure.
Just changed the command line. No difference. Slow on flacs....
EDIT: behavior is very unpredictable. Just now I noticed a very smooth operation, with flac files.
PB
PB
PieterB
