autostart Subsonic on Openfiler NAS
Postby chuckles » Thu Aug 16, 2012 2:10 am
I have installed the latest beta of Subsonic on a Openfiler NAS and everything is working splendidly except I can't get Subsonic to start automatically after a reboot.
/etc/rc.local looks like this:
#!/bin/sh
# This script will be executed *after* all the other init scripts.
# You can put your own initialization stuff in here if you don't
# want to do the full Sys V style init stuff.
touch /var/lock/subsys/local
sh /var/subsonic/subsonic.sh
This does not work and I see this in subsonic_sh.log:
/var/subsonic/subsonic.sh: line 113: java: command not found
Of course when I run the script manually, it works fine.
What am I doing wrong?
A
chuckles
Re: autostart Subsonic on Openfiler NAS
Postby chuckles » Tue Aug 21, 2012 1:44 pm
Any Linux gurus out there that can lend a hand?
chuckles
Postby bushman4 » Tue Aug 21, 2012 1:46 pm
If I had to guess the path variable is not set correctly, but I'm not a linux guy.
Have you tried changing that line in the script file to point to the explicit location of the java executable?
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: autostart Subsonic on Openfiler NAS [SOLVED]
Postby chuckles » Tue Aug 21, 2012 3:28 pm
Thanks for your suggestion.
I found the location of Java and changed:
# JAVA=java
to
JAVA=/usr/lib/jvm/sun-java-5.0u17/bin/java
and all is good now.
chuckles
Users browsing this forum: Bing [Bot] and 23 guests
