Album artwork thumbnails not generating
Postby Bellfazar » Thu Aug 16, 2012 3:28 am
I'm running a WAR deployment of SubSonic 4.7b3 on Tomcat 6 on Windows 7 x64. Most of my media is being pulled off of a Windows Home Server, so the Tomcat service is being run as a user that has access to the WHS. Whenever I try to load up a thumbnailed album art image, I get the following in subsonic.log:
[2012-08-15 23:18:24,567] WARN CoverArtController - Failed to create thumbnail for E:\Music Backup\Music\Ice Cube\Death Certificate\Artwork.jpg
javax.imageio.IIOException: Can't create cache file!
at javax.imageio.ImageIO.createImageInputStream(Unknown Source)
at javax.imageio.ImageIO.read(Unknown Source)
at net.sourceforge.subsonic.controller.CoverArtController.getCachedImage(CoverArtController.java:199)
at net.sourceforge.subsonic.controller.CoverArtController.handleRequest(CoverArtController.java:115)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:625)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:470)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: The system cannot find the path specified
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(Unknown Source)
at java.io.File.createTempFile(Unknown Source)
at javax.imageio.stream.FileCacheImageInputStream.<init>(Unknown Source)
at com.sun.imageio.spi.InputStreamImageInputStreamSpi.createInputStreamInstance(Unknown Source)
... 60 more
I suspect it's a permissions issue, but the account Tomcat is running under has permission to write to any sub-folder of the subsonic folder.
Can anyone help?
Please let me know if there's any more information that I can provide.
Bellfazar
Re: Album artwork thumbnails not generating
Postby Bellfazar » Thu Aug 16, 2012 10:10 pm
I figured out what was causing the issue. When ImageIO.read() creates an instance of ImageIO.createImageInputStream() it requires %TOMCAT_HOME%\temp to be defined and writable by the account the Tomcat service is running under in order to cache the InputStream. I didn't have that folder, consequently ImageIO.read() would throw an error.
Bellfazar
Postby madhusker » Mon Apr 01, 2013 2:07 am
I'm running this on a QNAP 569L and the solution is to create the tmp directory which doesn't get created by the QPKG:
mkdir /share/MD0_DATA/.qpkg/Subsonic/home/tmp
[2013-04-01 02:04:17,000] WARN CoverArtController - Failed to create thumbnail for /share/MD0_DATA/Music/Alternative/BRR/Shake! Shake! Shake!/08 - Broken Ocean.mp3
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
Caused by: java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
... 56 more
madhusker
